SC400SunDevil Posted December 8, 2003 Share Posted December 8, 2003 Who's got the highest miles? I have about 88K on my sc400, just curious to see how many miles people had, and what major repairs they've done. Quote Link to comment Share on other sites More sharing options...
jimH93 Posted December 8, 2003 Share Posted December 8, 2003 I have 120k on my 93LS400 Replaced a O2 sensor and a TP sensor, and an alternator. I have owned the car since 86K. Jim Quote Link to comment Share on other sites More sharing options...
Sadistic Posted December 8, 2003 Share Posted December 8, 2003 I have 170K still no major mechanical problem other than the O2 sensor that was fixed not too long ago. Even that I don't consider a major mechanical problem. Quote Link to comment Share on other sites More sharing options...
mad zorba Posted December 8, 2003 Share Posted December 8, 2003 164,507 miles on my '93 SC400. Bought the car in September and have done nothing to engine/drivetrain other than change engine oil and tranny fluid. Runs great! Needs more exhaust noise! Plan to have timing belt, water pump and suspension bushings changed after Christmas. I Bought a used CD changer on ebay and will install it after I figure out/research how to better isolate from vibration. Besides CD changer, the only other things that need fixing are one burned out bulb on climate control display and flickering temperature gauge needle. One of the best things about these cars is that they are RARE (at least in Sacramento). I've only seen eight others in my area (5 SC300s and 3 SC400s). Quote Link to comment Share on other sites More sharing options...
Bandit Posted December 8, 2003 Share Posted December 8, 2003 181,550 Miles 93 SC400 Most of the components that seem to give most owners a problem were taken care of by my Mother-In-Law before I took possession. New Alternator, Power Steering Pump, Starter, Radiator Reservoir, Water Pump, Gauge Cluster, Drivers Door Hinge, Head Light Assys, Mirror Remote ECU and a few other items. All items through Dealer Service "Ouch!". She also had every Factory Service: 1,000 Miles 15,000 Miles 60,000 Miles 105,000 Miles 160,000 Miles And, new tires in July! What else could a guy ask of his Mother-In-Law! The only item I have to fix is the LCD on the Climate Control Unit. I've since replaced Shocks and Springs with Tokico and Eibach, Green Stuff Pads, Stainless Steel Brake Lines, Drilled and Slotted Rotors. Leather Repair to a split seam in the Rear Seat. Repaired Power Antennae by disassembling and cleaning. Thought I would have to replace the wheels, but got some Buffing Compound and worked them over real well and then waxed them and they look quite nice. Removed Drivers Door Panel and rebuild the inside bracing with Epoxy and metal tabs. Removed all the leather interior and cleaned and conditioned with Lexol Leather Products. Leather interiors seem to be the most neglected part of the car. Compression checks were amazing! Within 2% of new specifications. Replaced plugs with Denso Iridiums, and the old plugs were burning very nice. Reading your plugs can tell you alot about how the major components of your engine are holding up. Most people are amazed that the car is 10 years old and just short of 200,000 miles. I think we will enjoy this automobile for many years to come! Quote Link to comment Share on other sites More sharing options...
alchemymike Posted December 9, 2003 Share Posted December 9, 2003 131,000 miles just changed alot of parts a/c lines, a/c compressor, power steering pump, power steering lines, belt, timing belt, plugs, wires, cap, rotor, water pump, thermostat, timing belt bearings. etc etc $4500.00 AND still going Quote Link to comment Share on other sites More sharing options...
brucelee Posted December 9, 2003 Share Posted December 9, 2003 My cousin has 248K on here 92 original owner sc400. Cannot get her to get another car. I have 104K on my 1995 sc400. Quote Link to comment Share on other sites More sharing options...
AWJ Posted December 9, 2003 Share Posted December 9, 2003 Mike!!! Ouch dog. Hey what are timing belt bearings? You need to find a different mechanic. Quote Link to comment Share on other sites More sharing options...
alchemymike Posted December 9, 2003 Share Posted December 9, 2003 the pulleys that the timing belt rides on other than the cam cogs. I just bought my sc400 off ebay for $3100 . my car was NEVER serviced thats why it needed so maney parts Quote Link to comment Share on other sites More sharing options...
Wick Posted December 9, 2003 Share Posted December 9, 2003 Yup, I had to replace those bearing on my 4-runner at 200K miles. They weren't too bad but I figured I should do it now instead of later. Too bad I didn't check the bearing that is in the center that the fan bolts to, it froze about month later and wiped out my new accessory belts. Ouch, $500 bucks to fix that one and I did the work myself. Wick Quote Link to comment Share on other sites More sharing options...
moemoe_xp Posted December 24, 2003 Share Posted December 24, 2003 1992 sc 400, i had it in 2001, no major mechanical problem, 240 000 KM Quote Link to comment Share on other sites More sharing options...
STOKED Posted December 24, 2003 Share Posted December 24, 2003 94,000 - and gettin' plenty of looks. Esp with my new front badge that costed me $100! Quote Link to comment Share on other sites More sharing options...
bean_8044 Posted December 25, 2003 Share Posted December 25, 2003 dont i feel like a !Removed!... my 91 Soarer has only ~80k km... course the island is only 40 miles long so i cant see how anyone could get that much mileage here Quote Link to comment Share on other sites More sharing options...
UCF3 Posted December 25, 2003 Share Posted December 25, 2003 I have 205,012 miles on mine. Although I'm not the original owner, but I know all of the belts, hoses, and fluids were replaced. I believe the previous owner gave up the car, after he heard the Oil Pan Gasket needed to be replaced. I had to replace the all of the filters, and the TP Sensor. Need to fix the oil pan gasket, clutch belt with a new shifter, and tires. Surprisingly the car is still running pretty well. Quote Link to comment Share on other sites More sharing options...
rich21 Posted December 26, 2003 Share Posted December 26, 2003 94 sc400. 107k. power steering pump, 2 alternators, radiator, belts, adn then there just regular stuff. Quote Link to comment Share on other sites More sharing options...
mktbully Posted December 26, 2003 Share Posted December 26, 2003 going to be picking up a 92 SC400...314K+ (no typo) . the owner is the orig owner. Quote Link to comment Share on other sites More sharing options...
arabian Posted December 26, 2003 Share Posted December 26, 2003 164K+ on my 92 SC400. Mom was the orginal owner and baby(ed) the car until I took it from her. She handed the keys over in 2000 with 52K. Luckily she was meticulous in her caring for the car. Makes me feel good to know that there are some of you out there with 200K+. Although I have my eye on an S2000, I can't see myself giving her up. Dad's the same way with his 91 M5..... can't give her up; runs in the family I suppose. Quote Link to comment Share on other sites More sharing options...
arabian Posted December 26, 2003 Share Posted December 26, 2003 going to be picking up a 92 SC400...314K+ (no typo) . the owner is the orig owner. Congrats, ahead of time, for the purchase. It says a lot when Toyota has to copy the exterior look of a ten year old SC300/400 for it 2001 edition of the Solara. Quote Link to comment Share on other sites More sharing options...
BlackSC4 Posted December 27, 2003 Share Posted December 27, 2003 going to be picking up a 92 SC400...314K+ (no typo) . the owner is the orig owner. sweet...is the engine rebuilt?? Quote Link to comment Share on other sites More sharing options...
UCF3 Posted December 27, 2003 Share Posted December 27, 2003 164K+ on my 92 SC400. Mom was the orginal owner and baby(ed) the car until I took it from her. She handed the keys over in 2000 with 52K. Luckily she was meticulous in her caring for the car. Makes me feel good to know that there are some of you out there with 200K+. Although I have my eye on an S2000, I can't see myself giving her up. Dad's the same way with his 91 M5..... can't give her up; runs in the family I suppose. S2000? You realize the SC330 and the Toyota Supra is coming out soon. Why leave the family? Quote Link to comment Share on other sites More sharing options...
mktbully Posted December 28, 2003 Share Posted December 28, 2003 going to be picking up a 92 SC400...314K+ (no typo) . the owner is the orig owner. sweet...is the engine rebuilt?? nope...orig engine. he just had the tranny redone. Quote Link to comment Share on other sites More sharing options...
UCF3 Posted December 29, 2003 Share Posted December 29, 2003 It says a lot when Toyota has to copy the exterior look of a ten year old SC300/400 for it 2001 edition of the Solara. I wouldn't say that. The New Solara looks closer to the New SC430 and future 330 than the older SCs. Even the future Supra looks similar to new Celica and SC430. I believe they're trying to keep the looks similar to each other. I don't know about you guys but it makes them look like they're not even trying anymore. Quote Link to comment Share on other sites More sharing options...
laxdude3622 Posted January 12, 2004 Share Posted January 12, 2004 I have a 1990 LS400, with about 294,000 miles on it. Running strong still, has a lil trouble starting up in the morning though. Quote Link to comment Share on other sites More sharing options...
UCF3 Posted January 12, 2004 Share Posted January 12, 2004 I have a 1990 LS400, with about 294,000 miles on it. Running strong still, has a lil trouble starting up in the morning though. How old is your battery? Quote Link to comment Share on other sites More sharing options...
laxdude3622 Posted January 12, 2004 Share Posted January 12, 2004 hmm i am not sure, the car is actually my dad's, but i drive it alot, and i might get it or sell it and get an sc400, but he bought it with about 220k, and i am not sure if he has change the battery Quote Link to comment Share on other sites More sharing options...
