lexfourcam Posted December 16, 2008 Posted December 16, 2008 Im really starting to worry about my car because i havent had it for a while now because its been in the shop. i was thinkin maybe it could be the wires running to the fuel injectors does any one have any clue im soooo confused!
jcrome04 Posted December 16, 2008 Posted December 16, 2008 Caps and rotors????? so so cheap to replace too.
dcfish Posted December 16, 2008 Posted December 16, 2008 Caps and rotors????? so so cheap to replace too. I agree with jcrome04 ;) By the way Happy Birthday lexfourcam
lexfourcam Posted December 16, 2008 Author Posted December 16, 2008 thanks for the replies i'll let the mechanics kno and thinks for wishing me a happy birthday maybe today will turn out better than it started. i'll keep you guys posted thanks.
lexfourcam Posted December 16, 2008 Author Posted December 16, 2008 got my car back tonite guys! turns out it had jumped timing. and that was causing it to run the way it did. runs like brand new now.
dcfish Posted December 17, 2008 Posted December 17, 2008 got my car back tonite guys! turns out it had jumped timing. and that was causing it to run the way it did. runs like brand new now. :cheers: Glad to hear that all is back to normal, How much $ for the work ?
eatingupblacktop Posted December 17, 2008 Posted December 17, 2008 Eight's always better than five! Too bad you're going to have to get used to that smoothness all over again, don't think it should take too long. :P Also didn't see DC's usual posting - HB
python Posted December 17, 2008 Posted December 17, 2008 jumped timing? i would like to know how it did that and how they determined it jumped timing? belt skip a tooth? i highly doubt that....cam sensor? no!
don corleone Posted December 17, 2008 Posted December 17, 2008 the belt can skip a tooth happened to me recently while i was replacing the cam seals. the belt was off maybe two teeth but it caused a CEL and the car was running strangly. i when in and fixed it and the car is fine now.
PureDrifter Posted December 18, 2008 Posted December 18, 2008 the belt can skip a tooth happened to me recently while i was replacing the cam seals. the belt was off maybe two teeth but it caused a CEL and the car was running strangly. i when in and fixed it and the car is fine now. its rare for the car to jump timing if there hasnt been any recent work done on it. may want to look at the tensioner.
lexfourcam Posted December 18, 2008 Author Posted December 18, 2008 thats what i was told but the last jack leg that worked on it was supposed to replace the timing belt because we thought that was the problem turned out to have a fried fuse box. and it never really ran good as it did since then and sometimes it would vibrate. but with that whole tune up the car runs amazing now runs better than the last time i drove it.
python Posted December 18, 2008 Posted December 18, 2008 well its the end result that matters i guess, but i dont think it jumped time...if the car is a tooth off the light comes on and throws a code...for it to run rough it would have to skip a few teeth
lexfourcam Posted December 19, 2008 Author Posted December 19, 2008 guys i have another problem. i kno the loc isnt for other cars but my girlfriends 94 toyota camry will not start. the other day i had driven it to get my car and it ran perfectly fine. the next day she goes to start it to go to work and it doesnt start. the starter turns the engine turns over and i just dont see how all of the plugs could have went bad. it doesnt run at all the starter just keeps turning the motor over. i was thinkin it could possibly be a fuse but if you guys could point me into the right direction i would appreciate it.
python Posted December 19, 2008 Posted December 19, 2008 u need to find out if its a fuel or spark issue...that is the first step, then u go from there
lexfourcam Posted December 19, 2008 Author Posted December 19, 2008 ok i'll check to see if the engines getting fuel and see if the plugs are firing i'll let you guys know tonite what ive found out. thanks.
