How would I distinguish between an AWD RX330 (2004 model year) and a FWD one? I see no badge that specifies "AWD" on the car, nor do I see any readily visible feature described in the owners manual that would exist on the AWD model but not the FWD model (or vice versa). Can anyone give me some guidance on how to easily tell them apart? Thanks.
Take a look under the car for a drive shaft to the rear axle.
Jef
As stated above, looking underneath's the only way.
Thanks to both for the advice. That's what I'll do.
Or the 4th digit of the VIN. H = AWD and G = FWD (at least for the 2004/2005 RX330 models...and maybe others, I am just not 100% sure).
I can confirm Newton's post. The fourth digit will determine AWD or FWD. Checking for Drive shaft is always the easiest way though..........
  • 1 year later...
Would you by any chance know, when and how this AWD feature kick in? Are all the wheels working (powered) at all times? Is there any article I could read to have an understanding about this? Thanks
Its there all the time.....non selectable.....
It detects slippage of the tires and does it's magic.
It's mostly in front wheel drive; power is sometimes sent to the rear when it thinks it's necessary.
  • 1 month later...
Okay, so I take my '04 AWD RX330 to the snow and chains or AWD is required. How does Caltrans/CHP kow what I'm driving?
Thanks....
Thanks....
Tell 'em to do the same thing you did- look underneath. Probably won't happen but it's good for a try. :lol:
Last time I went to Reno when it was snowing they just waved me by, they didn't even ask or stop me.
Jeff
Typically if you are driving a road that has a chain up inspection, you just hold up 4 fingers to the troopers there. They understand that to mean you are 4wd.
