Latest Posts
Showing topics posted in for the last 365 days.
- Past hour
Engine Noise on 2013 ES 250
RX400h replied to jerryk22's topic in 2019 - Present ES250 / ES300h / ES350 / ES350h
Hopefully, you'll get a direct answer, but I am curious why you would not consider an ES300h. My sister has one and cannot be any happier, especially with its stellar gas mileage of 42 MPG average and up to 50 mpg on the highway. -
2018 rx350 fsport ac hot on drivers side
RX400h replied to Speng's topic in 16 - 18 Lexus RX350 / RX450h
DEAD THROTTLE, CEL, VSC OFF . 2000 RPM limit
RX400h replied to tprjim's topic in 01 - 10 Lexus SC430
- Today
I need to update my 2015 es300h navigation maps.... what is the correct part number for the latest simm card update ? Can I buy it from amazon or have there been problems with those ? thank you for any help you can give me. ..Jim
- Yesterday
I don't think that motor is available anymore. It is also part of the bracket. I have heard that lubricating these motors will kill them. Which probably won't matter if it's already dead.
I have a 2006 SC430. I can’t unlock the doors or open the truck using the key fob. The battery is good the little red light on the fob works. Everything in the car works fine. Door locks lock and unlock using the buttons in the car. The button in the car that opens the truck does not work. Any suggestions?
- Last week
1998 Ls400 Throttle Body Removal And Cleaning
paulo57509 replied to richardkwon's topic in 90 - 00 Lexus LS400
Draining just the radiator should be sufficient. You do know the proper procedure on how to refill and bleed the cooling system? -
The lower shaft descriptions are confusing; non-tilt, tilt, can't install it on the column, etc. I've never done column work on the LS, other than to lower it from the dash to access the ignition switch. In order to disassemble/assemble the column, I would recommend removing it from the vehicle and working on it on a bench. Hopefully, the attachments will be of some help. SR-12 Power Tilt and Power Telescopic Steering Column - Removal.pdf SR-14 Power Tilt and Power Telescopic Steering Column - Disassembly.pdf SR-19 Power Tilt and Power Telescopic Steering Column - Reassembly.pdf SR-22 Power Tilt and Power Telescopic Steering Column - Installation.pdf
So I was cruising along in my pristine 2011 LX 570 STOCK(as the should be). Do not even get me started on the idiots who ruin the reputation of the brand by "modding" or "tricking out" there vehicles. Anyways. There I was jamming out to my favorite classic rock station, when I pull into the gas station, when I see the most sensational women I have ever seen filling up her '97 chevy. She comes over my beautiful car( as it does attract quite a bit of female attention), and leans into my window. She proceeds to tell me how much she fancies the 5.7 Liter V8 in my absolute horse of a vehicles. After inviting her into my car, she tells me there is something wrong with my car. Excuse me. Not my 2011 Lexus Lx 570. After reaching around I realize that my vehicle is upequipped to handle the sheer power of a bigger women. Let me tell you know if she aint over 280 she aint a lady. Live by that die by that. Anyways. I would like to file a complaint to Lexus about the structural integrity of their passsenger seats in the first gen Lx 570s. If anyone could help me resolve this tragedy, that would be greatly appreciated.
Agree. I had mine installed by the dealer. Price, including install was less than ordering the parts from Rock. Also the originals lasted 16 years, I doubt any of the aftermarkets will last even close to that long, assuming they even work right. If your vehicle is old enough it doesn't already have TPMS, I have no advice, never tried the remote cap ones.
deluciadominick88@gmail.co mine is the tail lights I just have brake lights Is it the module
- 6 replies
- trim removal
- brake light failure sensor
(and 1 more)
Tagged with:
navigation update for 2016 es350
ArthurW replied to Dorothy Pennachio's topic in 2013 - 2018 ES350 / ES350h
@tomscot2 Whew. What a relief the system sorted itself out eventually. Odd that it didn't do so within minutes of the upgrade. Glad you're sorted. -
Any updates on the car?
actually, the question I think you’re looking for is what mutes the amplifier after it fires up mine plays for about two3 seconds and quits after turning on the ignition I can turn the ignition off and back on again and the musical play again for 2 to 3 seconds I hear a pop through the speakers. All speakers have been checked and worked perfect and hear the amplifier turn on, but do not hear the amplifier turn off. Is there a communication box between the radio and the amplifier with a digital mute line
Hello I just got my 2024 RX 500h F sport. I love everything about it except the Sound system. I’ve tried adjusting and readjusting but sitting in the driver seat still sometimes sounds like a tin can. I realize that it depends on what I’m listening to, when it was recorded, and other factors that make it sound good or not so good. But I’m wondering if there’s anyone out there who has made any changes to the Sound system to make it better and if you were successful, what did you do? I have the Levinson 21 speaker Sound-system.
LS 460 won't start after battery charge.
dcfish replied to Spencer Cox's topic in 07 - 16 Lexus LS460 / LS460L / LS600h
You charged a trash battery, Buy a new one. -
Hi Everybody, My name is Mira I'm new to the forum. I have owned my 2014 CT200h for 8 years and it has been a super dependable car. I recently had an electrical issue and my brother said the code P0A80 was a hybrid/EV battery pack replacement code. My question is what are your recommendations for replacement. I see a lot of options out there and since I have an electrical engineering background, replacing the pack myself is not a problem and will save me a lot of money. I searched the site but did not see anything on this topic which surprised me. Thank you
Did I make mistake getting the RX350 Premium+ gas version? Should I have gotten the NX350H instead? MSRP price for 2024 RX Premium Plus was $58,900.00 and I got it for $51,200.00 plus tax amd fees. I thought it was good deal so I got it. I could have gotten the NX350H Premium with HUD for about $52k plus tax and fees but would save about $500 per year on gas. The NX350H premium however doesn't have real leather, no digital rear mirror and no advance parking. These additional features don't seem necessary though. I'm a bit regretting not getting the RX350H instead... Please share your thoughts. Thank you!
Keep Having To add Anti Freeze
rolando replied to Rocca's Lex's topic in 93 - 05 Lexus GS300 / GS400 / GS430
look for coolant under passenger and rear passenger wet carpet. Possible leaking heater core . -
click or knocking noise
JMSC replied to Mike S7749's topic in 2019 - Present ES250 / ES300h / ES350 / ES350h
Mention to the dealer to check the top strut mounts for tightness. -
P0128 engine code and no voltage from coolant harness
RX400h replied to burnse's topic in General Maintenance
Topics
