TexasLexus94 Posted April 28, 2004 Share Posted April 28, 2004 My 94 LS400 has had the brakes reworked 3 times in the last 14,000 miles. 2 times by the previous owner, and once by me. The Lexus dealer ground the rotors and replaced the pads both times. I took the car to an Indie because the brakes were "shuddering" a bit on stopping. He looked at the shoes, and said they looked nearly new-I agreed, so I had him grind the rotors only. The rotors did look very rough. Now the brakes have a small shudder, but they also "squeal" upon a light pressure on the brakes. I'm thinking maybe the rotors are worn out, and that they should be replaced. I'm sure the car, which has 120,000 miles, has had other brake jobs, too. Just looking for ideas-Thanks a lot. Quote Link to comment Share on other sites More sharing options...
Lextreme Posted April 28, 2004 Share Posted April 28, 2004 why not do supra TT front brake upgrade.. Supra TT Brake Upgrade Quote Link to comment Share on other sites More sharing options...
jschunke Posted April 28, 2004 Share Posted April 28, 2004 If your still getting brake shutter then replace the rotors and be done with it. By the time you pay for the labor to have them cut you may as go the extra mile for new ones. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted April 29, 2004 Share Posted April 29, 2004 I just realized that I drove my 1st LS almost 185,000 miles on the original rotors and the new owner is still driving on the originals. Early LS cars (90-92) were particularly sensitive to overtightening the lug nuts which led to rotor warping. Although the issue was addressed somewhat in '93 with more robust rotors, most cars are sensitive to overtightened lug nuts. It is important to tighten LS lug nuts evenly and to not exceed 76 ft. lb. of torgue. An air wrench should never be used. A Lexus dealer mechanic once torqued my lug nuts to about 150 ft. lbs. so now I check the torque myself after anyone removes the wheels. Your indie mechanic should be able to tell you if the rotors are warped. Quote Link to comment Share on other sites More sharing options...
tansupplyman Posted April 29, 2004 Share Posted April 29, 2004 My suggestion is to 'wait a while' !!!!! You had the rotors turned and did not install new pads--thus pads aren't seated yet. Rotors should not be rough !!!!! unless you are rubbing in a axial direction with your fingernail. New rotors are 'lapped'--not rough. Could be the shop was using dull cutters and they were 'chattering'--that will rough it up. maybe they will smooth out. just wait about 400-500 miles and see what happens. Rotors are only worn out when they go below min thickness. Heed the torque comment. If it continues, then bite-the-bullet and get new rotors. Don't think you need a battleship anchor for a fishing boat--unless you race the thing!!!!!! Mine are original with 165k---but whenever they shutter again-it is new ones for me. Quote Link to comment Share on other sites More sharing options...
dole2000 Posted April 29, 2004 Share Posted April 29, 2004 I have a 1991 and would like to replace the rotors with aftermarket Bremble Rotors. But, for some reason they are never available for 1993 and newer LS 400's. Does anyone know why this is? does anyone know where I can get some drilled and slotted rotors? Thanks, Bob Quote Link to comment Share on other sites More sharing options...
SKperformance Posted April 29, 2004 Share Posted April 29, 2004 Your indie didn;t check the min spec for rotor thickness? i would also check to see if you have sticking sliders causing the brakes to heat unevenly Quote Link to comment Share on other sites More sharing options...
terrimac Posted April 30, 2004 Share Posted April 30, 2004 My 91 LS400 had a similar problem and then I had to replace the calipers because they were freezing up. Haven't experience that problem since Good luck! Quote Link to comment Share on other sites More sharing options...
445187 Posted May 12, 2004 Share Posted May 12, 2004 :cries: Why hasn't anyone responded to the question about drilled/slotted rotors Quote Link to comment Share on other sites More sharing options...
VMF Posted May 13, 2004 Share Posted May 13, 2004 i personally dont know any bugdet drilled/slotted rotors and i dont have $ to get brembo setup but since my rotors are gettin worse and they squeak all the time i will have to go for the stock oem replacement. Quote Link to comment Share on other sites More sharing options...
dole2000 Posted May 13, 2004 Share Posted May 13, 2004 There is a guy on Ebay called nights auto. He has them for the front for $105.00. They are cadmium plated. I am going to order a pair. Will let you know how it goes. Bob Quote Link to comment Share on other sites More sharing options...
VMF Posted May 13, 2004 Share Posted May 13, 2004 i would love to know how they will fit and work:) Quote Link to comment Share on other sites More sharing options...
UCF3 Posted May 13, 2004 Share Posted May 13, 2004 I think the ones being sold on Ebay are okay, but will wear as fast as your OEMs. 445187 : What's your budget when Big Brake Packages? Your welcomed to contact the guys who made my Wilwood Package. The fronts were $1500 instead of the $2k. Quote Link to comment Share on other sites More sharing options...
