smooth1 Posted October 12, 2008 Share Posted October 12, 2008 The tools you will need are: Spring Compressor ( You can get this as a free loaner tool from any Advance Auto Parts. I'm sure other auto parts stores offer the same programs.) 10mm, 12mm, 14mm, 17mm, 19mm, sockets and wrenches. 3/8 drive for the 10-17mm should be fine, but I would strongly suggest a 1/2 drive for the 19mm. I also used a 25 inch flex handle breaker bar. Floor jack and jack stands. 1 spare screw type or small hydraulic jack 6mm, 8mm allen wrenches Hammer A small standard screw driver, a medium phillips head screwdriver Torque Wrench 2 coil spring wrenches( These should have come with the coilsprings.) The new springs: Step 1) I started with the rear suspension first. You don't have to, I thought it was just easier to get these out of the way as the rear coils for the Tenabe Pro Sustec's reuse the stock hats and upper mounts. So start by removing the trunk liner. There are 3 slide latches under the trunk deck you just pull toward you and remove. Next I used a small screwdriver to slide into the retainer slips and popped them out. I also noticed latches on the floor of the trunk ( the silver ones for bungy cords and so on) have a reverse black cover that pulls out revealing a phillips screw that will need to be removed. Also be careful of the wire for the trunk light. Just pop it off at the light and now you can remove trunk liner. 2) Jack up the car and place the jack stands for safety. I used the center brace right behind the differential for the floor jack, and I just located 2 points for the jack stands. 3) remove the rear wheels. 4) Loosen the top mounts with a 14 mm wrench inside the trunk. Remove the 12mm nut holding the sway bar endlink to the control arm. Then remove the 17mm nut and bolt connecting the coilover to the control arm, and the 17mm nut/bolt that holds the control arm to the hub assembly. Now using a 10 mm socket and extension, you'll need to remove the tire well lining around where the coilover is to get access to the two 12mm bolts that anchor the coilovers to the chassis. I circled the 10 mm bolts to remove the liner, and pointed the arrows at the 12 mm bolts to be removed underneath. 5) Now finish removing the 14mm bolts that hold the upper mounts on, and carefully push the control arm down to allow enouph room for the stock coilover to come out. BE CAREFUL!! The rubber hose on your right is a brake line. Stock coilover: With the Tanabe coilover, and with Tein and others as well, you have to reuse the stock strut hat and bumpstops. So at this point your going to need to use the spring compressor on the stock coilover and compress the spring in order to take the tension off the hat. Do not attempt to disassemble the coilover before or without the spring compressor. Don't over compress the spring as well. In the picture above, I circled the center coil seat. There is a rubber seat there. You can see when the coil is compressed enouph by looking at that seal. You don't want to create a gap there, you just want to uncompress that rubber seat. Once you have done that, you can remove the 17mm nut that holds the strut hat on. I would still unthread this slowly as the rubber mounts will expand and make a slight "pop" also now. Now slide the hat up and off: And now slide the oem bump stop washer, bushing and collar off. Keeping the assembly the same slide it on the new coilover: And now put the OEM hat on the new coilover and tighten the strut bolt.*Tip: try to make sure the thrust washer/joint seal is seated correctly. and if your new coilover has helper springs, make sure the end of the helper spring isn't directly over the end of the coilspring itself. I allways turn them 90 degrees from each other. It's a common mistake that gets made and can lead to a coil squeak noise later. 6) Your now ready to slide the coilover back into positon. At this point it would be good to have a friend guide the top of the coilover back into the upper mount while you work on positioning the lower mounts and moving the control arm back into place. If you don't have a friend, then you may need to put on some safety glasses so you can look straight up into the upper mount from underneath the car and work it into position. 7)Replace all the bolts and nuts. A note here: tighten the lower control arm bolts first, then the two 12mm support bolts on the well, then do the upper mounts last. You have to make sure the coilover in aligned and correctly seated. If you tighten the upper mounts first, you won't be able to tell if it is aligned right or not. 8) It's going to be up to you to determine the correct ride height. So, I would just put the lower seat collars in the middle of the threading for now. Make sure you lock the seat tight with the locking collar so they don't move. Keep in mind that over the next 2 weeks, the coilover springs are going to settle a bit. I would wait atleast that long to determine the exact height setting you want then. For now we just want to put everything on correctly. And come back later to get the ride height dialed in. You'll see how I did that process later in this tutorial. 9) Torque everything down, and double check all your bolts and lines. Do the same for the other side. Replace the trunk liner and your now ready to move to the front suspension. 1 Quote Link to comment Share on other sites More sharing options...
smooth1 Posted October 12, 2008 Author Share Posted October 12, 2008 1)Jack up the front end of the car and place your jack stands for safety. Remove the plastic side panels in the engine bay. 2) remove the front wheels. 3) Use a 14mm socket to loosen the upper mounts. 4) Now use a 10mm socket to remove the receiver wire from the shock housing. And the 10 mm nut that holds the headlight leveling sensor. 5) Now remove the 17mm nut that holds the lower shock in place. (It was easier if you turn the wheels all the way to the opposite side your working on with the steering wheel.) In the pic above, this nut was a BUSTER to get off! I ended up having to use a breaker bar to get this loose. It may not be that hard for all. But just be prepared in case it is. 6) I have found it much easier to remove the cotter pin and the 17mm bolt at the top of the A-arm to make room for the coilover to slide out. Like this: 7)Tip: Don't completely remove this nut yet. Just loosen it all the way to bottom of the threading like this: Then tap on the A-arm with a hammer until it comes free. This will make sure the arm and roter don't just flop out at you when it comes free. Now just hold the A-arm and remove the nut. Then move the arm to allow acces to the coilover. 8) Remove the stock coilover. 9) Slide into the place the new coilover. Again, making sure you hand tighten the lower bolts first. 10) reattach the 10 mm bolt holding the reciever wire and all the other bolts. 11) Make sure you torque down the upper mounts last again, and then double check all your bolts and lines. Make sure you torque all your lugnuts on your wheels down properly. The finish results: * pics courtesy of the wife. :) 1 Quote Link to comment Share on other sites More sharing options...
IS250_rookie Posted October 13, 2008 Share Posted October 13, 2008 wow thanks for the work :) the car looks really sick with the tints and a lower ride height Quote Link to comment Share on other sites More sharing options...
BaddBoi70 Posted October 13, 2008 Share Posted October 13, 2008 I'M JEALOUS Great post Smooth! WOW - I love the lowered stance and I can only imagine how much nicer the ride is with the mods - ENJOY Quote Link to comment Share on other sites More sharing options...
raymsixsix Posted October 13, 2008 Share Posted October 13, 2008 As usual, what a great writeup Smooth! I didn't realize you got a new IS. Black on black is the most beautiful, it looks sexy yet dangerous. Quote Link to comment Share on other sites More sharing options...
smooth1 Posted October 14, 2008 Author Share Posted October 14, 2008 Thanks guys! :) I drove it in to the shop today. I gotta say, it's such an improvement. No matter how many times I do this mod, I'm allways surprised at the before and after differences in ride quality. I can hardly wait until my rims come in now! And with the new adjustable camber kit that should be ready in mid November, I should be able to stay pretty aggressive with the lower ride height, and dial up the camber enouph to save the tires. Lovin the timing!!! As usual, what a great writeup Smooth! I didn't realize you got a new IS. Black on black is the most beautiful, it looks sexy yet dangerous. Yeah, I got the new IS 350 about 8 months ago now. It's my daily driver now. Quote Link to comment Share on other sites More sharing options...
flop170 Posted October 14, 2008 Share Posted October 14, 2008 hellz ya!! looks great Quote Link to comment Share on other sites More sharing options...
dcfish Posted October 14, 2008 Share Posted October 14, 2008 What a great write-up Smooth Looks great and I am sure it drives even better........... Quote Link to comment Share on other sites More sharing options...
bartkat Posted October 14, 2008 Share Posted October 14, 2008 Ditto. Quote Link to comment Share on other sites More sharing options...
smooth1 Posted October 19, 2008 Author Share Posted October 19, 2008 Thanks again guys! :) Quote Link to comment Share on other sites More sharing options...
Jay.Diem Posted October 24, 2008 Share Posted October 24, 2008 wow ... just bookmarked! Quote Link to comment Share on other sites More sharing options...
IndyKen Posted October 30, 2008 Share Posted October 30, 2008 Yes, great detail on the write up Smooth. Question though. I am just swapping my stock shocks out for set of Bilsteins and another post on MYIS showed you had to compress the springs and didn't mention anything about loosening the Upper control arm nut. Did I miss something? Many thanks, Ken Quote Link to comment Share on other sites More sharing options...
smooth1 Posted October 30, 2008 Author Share Posted October 30, 2008 Yes, great detail on the write up Smooth. Question though. I am just swapping my stock shocks out for set of Bilsteins and another post on MYIS showed you had to compress the springs and didn't mention anything about loosening the Upper control arm nut. Did I miss something?Many thanks, Ken Hmm, I haven't seen the MYIS thread your referring to, but I do it that way as a "short cut". They may have not been aware of doing it this way, or maybe just missed putting it in thier thread. The upper bolt and cotter pin are allways 100x's easier to get off and put back on. There are a couple ways to do it, but like I said, I just found this way alot easier. Once you jack up the car, and pull the tire off, you'll be able to determine for yourself. Once you do, let me know what way you went, and how it worked out. ;) Quote Link to comment Share on other sites More sharing options...
IndyKen Posted October 31, 2008 Share Posted October 31, 2008 Yep Smooth, I took your way. It was much easier than unbolting the entire shock mounting bracket (lower) See the other post here. http://my.is/forums/f67/is300-coil-spring-install-341238/ The whole assembly slid right out and the new one slid right back in. Again, great write up and especially the part about LOOSENING the upper control arm bolt first rather than taking the whole nut off at once!! Not so good to have the entire rotor assembly smacking you in the face. Appreciate the reply, Ken Quote Link to comment Share on other sites More sharing options...
smooth1 Posted October 31, 2008 Author Share Posted October 31, 2008 Yep Smooth, I took your way. It was much easier than unbolting the entire shock mounting bracket (lower) See the other post here. http://my.is/forums/f67/is300-coil-spring-install-341238/ The whole assembly slid right out and the new one slid right back in. Again, great write up and especially the part about LOOSENING the upper control arm bolt first rather than taking the whole nut off at once!! Not so good to have the entire rotor assembly smacking you in the face. Appreciate the reply, Ken :) Quote Link to comment Share on other sites More sharing options...
HHRP Posted June 19, 2009 Share Posted June 19, 2009 Great job. Especially doing it yourself. So, do you feel a difference in ride? Nothing rubs? Quote Link to comment Share on other sites More sharing options...
smooth1 Posted June 19, 2009 Author Share Posted June 19, 2009 Great job. Especially doing it yourself. So, do you feel a difference in ride? Nothing rubs? The ride is better imho. And no rubbing issues either. I've even put new rims on since this thread with more aggressive offsets and I still don't rub. If you click on the link below you can see it for yourself. pic of car with new rims Quote Link to comment Share on other sites More sharing options...
HHRP Posted June 19, 2009 Share Posted June 19, 2009 Man, it looks great! Are these rims lighter than the stock? Quote Link to comment Share on other sites More sharing options...
smooth1 Posted June 19, 2009 Author Share Posted June 19, 2009 Yeah, just a bit... lol! Quote Link to comment Share on other sites More sharing options...
jzflsrt Posted January 8, 2010 Share Posted January 8, 2010 HELLO SMOOTH 1. i WOULD LIKE TO ASK YOU FOR ADVICE REGARDING COILOVERS... I Just installed my car with dampers coilovers on my 2003 IS300. I have 225/40/18 Front & rear. I am not sure how much the vehicle is lowered. all I can say the car feels and look nice. can you tell me how to adjust the camber. Please post how. I have called and taken my car to several reputable shops that do alignments and all are stating that the camber in the front isn't adjustable and the rear, may only be adjusted up to +-.3 If I need to buy a camber kit and witch one work best, please advise must shops are saying that i will need to put on a set of camber kit, but if it isn't necessary, please instruct me on what to tell these shops that are stating that there isn't anything to adjust. Thanks. I didn`t need to replace the rear strut mount because they came with theire own, but i noticed that the stock are like curbed. I hear a noise on the rear like if the coil may be rubbing because they are straight and not like the stock. Does that mean the coil is rubbing on the chassy? or is it because it need to be align. please help and thatk you for posting a link how to install coilovers. it help me alot thanks. Quote Link to comment Share on other sites More sharing options...
smooth1 Posted January 8, 2010 Author Share Posted January 8, 2010 HELLO SMOOTH 1. i WOULD LIKE TO ASK YOU FOR ADVICE REGARDING COILOVERS...I Just installed my car with dampers coilovers on my 2003 IS300. I have 225/40/18 Front & rear. I am not sure how much the vehicle is lowered. all I can say the car feels and look nice. can you tell me how to adjust the camber. Please post how. I have called and taken my car to several reputable shops that do alignments and all are stating that the camber in the front isn't adjustable and the rear, may only be adjusted up to +-.3 If I need to buy a camber kit and witch one work best, please advise must shops are saying that i will need to put on a set of camber kit, but if it isn't necessary, please instruct me on what to tell these shops that are stating that there isn't anything to adjust. Thanks. I didn`t need to replace the rear strut mount because they came with theire own, but i noticed that the stock are like curbed. I hear a noise on the rear like if the coil may be rubbing because they are straight and not like the stock. Does that mean the coil is rubbing on the chassy? or is it because it need to be align. please help and thatk you for posting a link how to install coilovers. it help me alot thanks. The IS 300 has camber adjustments in the front. You'll probably have to take it to Lexus or atleast a Toyota dealer to have them adjusted. Most tech shops won't or can't adjust the camber as they don't have the right tools. I had my IS300 lowered about an inch and a quarter to an inch and a half and I was just outside of factory spec with the camber dialed all the way in. I don't think you your going to need a camber kit. Kit's are more for being able to change the camber easily so you can be track ready. You shouldn't be having any rubbing or noises coming from the struts. Are you sure you have the right one on? If they are rubbing or they are misaligned, your going to considerable shorten the lifespan of the struts. Quote Link to comment Share on other sites More sharing options...
jzflsrt Posted January 9, 2010 Share Posted January 9, 2010 yesterday I had taken out the rear coilover from the rear again and even dissasabble it to see if i had done something wrong,but everything seem right. I think it may be comming from the bump stop as when the car travels . can that be an issue? is very hard to hear were is comming from i hear it also when i bounce the car. i recheck all the other areas that i have loosen on installation but theire all tight. the reason i said is comming from the stop mount is because when innitially adjust the sprin to were i can turn it manually, the stiffer i put them the less i hear the sound, but i dont want them to put them to stiff. any other suugestions??? Quote Link to comment Share on other sites More sharing options...
Djmo20 Posted March 23, 2010 Share Posted March 23, 2010 Great job. Especially doing it yourself. So, do you feel a difference in ride? Nothing rubs? The ride is better imho. And no rubbing issues either. I've even put new rims on since this thread with more aggressive offsets and I still don't rub. If you click on the link below you can see it for yourself. pic of car with new rims hello smooth...your car is beautiful. Could you tell me what size your rims are... Quote Link to comment Share on other sites More sharing options...
smooth1 Posted March 23, 2010 Author Share Posted March 23, 2010 Great job. Especially doing it yourself. So, do you feel a difference in ride? Nothing rubs? The ride is better imho. And no rubbing issues either. I've even put new rims on since this thread with more aggressive offsets and I still don't rub. If you click on the link below you can see it for yourself. pic of car with new rims hello smooth...your car is beautiful. Could you tell me what size your rims are... http://us.lexusownersclub.com/forums/index...tem&CID=205 Quote Link to comment Share on other sites More sharing options...
CarLighTrends Posted March 27, 2010 Share Posted March 27, 2010 I've never seen such a detailed write-up on a suspension install except in a magazine, well done. Quote Link to comment Share on other sites More sharing options...
