deepcdiver Posted December 9, 2004 Share Posted December 9, 2004 My Check Engine light stays on, need to get it off for smog cert (comes on again afetr disconnecting the battery). Dealer checked it out, sensors and EGr valve OK, said the EGR pipe needs cleaning. Sounds like someting I should be able to do myself, but how??? Quote Link to comment Share on other sites More sharing options...
silvermate Posted December 9, 2004 Share Posted December 9, 2004 here is something Lexls has, i've done it too, don't know if it would help you or not but here it is http://www.lexls.com/egrfilter.html 92LEx is the emmissions guru, i'm sure he'll chime in later. Quote Link to comment Share on other sites More sharing options...
92Lex Posted December 9, 2004 Share Posted December 9, 2004 You need a MotorVac to clean out the clogged EGR pipe. You're going to have to bring it to a shop to have it done, unless you have one of these at home (which I doubt). Quote Link to comment Share on other sites More sharing options...
deepcdiver Posted December 9, 2004 Author Share Posted December 9, 2004 Thanks for the info, guess I'll bite the bullet and take it in, I'm such a cheap *BLEEP* :chairshot: You need a MotorVac to clean out the clogged EGR pipe. You're going to have to bring it to a shop to have it done, unless you have one of these at home (which I doubt). ← Quote Link to comment Share on other sites More sharing options...
VBdenny Posted December 10, 2004 Share Posted December 10, 2004 I was as well.... at least until I bought this Lexus. I don't much like spending the money but since I don't have any car payments I guess it isn't too bad. Then I drive it on the Interstate and know it is all worth the price. I have fixed a lot of things on this car from stuff I learned here. Quote Link to comment Share on other sites More sharing options...
Lexls Posted December 10, 2004 Share Posted December 10, 2004 EGR pipe cleaning? I thought that the EGR pipe was located at the back of the engine and a pain in the *** to even change. 92Lex, would you care to elaborate on this procedure...? I'm confused here. Quote Link to comment Share on other sites More sharing options...
92Lex Posted December 10, 2004 Share Posted December 10, 2004 You don't have to remove it from the vehicle. Just hook up the pressure and return lines of the MotorVac and it cleans the engine using detergents/fuel. Cleans O2S, spark plugs, ports, valves, injector housings, cats & EGR. It's like $100 at most shops around here...well worth the money though. Quote Link to comment Share on other sites More sharing options...
Jacob Posted December 10, 2004 Share Posted December 10, 2004 92Lex, I've been looking for a shop that does MotorVac in Phoenix metro with no success. Is this something done at a repair shop? or is it done at an oil lube? It seems that some mechanics have no idea what MotorVac is. any ideas on how to find a MotorVac :) Quote Link to comment Share on other sites More sharing options...
silvermate Posted December 10, 2004 Share Posted December 10, 2004 You don't have to remove it from the vehicle. Just hook up the pressure and return lines of the MotorVac and it cleans the engine using detergents/fuel. Cleans O2S, spark plugs, ports, valves, injector housings, cats & EGR. It's like $100 at most shops around here...well worth the money though. wow, it cleans all of that for 100 bucks? man i'm gonna do that, that sounds like a maintence must......do you know of a general auto chain that does that procedure Quote Link to comment Share on other sites More sharing options...
99lsguy Posted December 10, 2004 Share Posted December 10, 2004 You don't have to remove it from the vehicle. Just hook up the pressure and return lines of the MotorVac and it cleans the engine using detergents/fuel. Cleans O2S, spark plugs, ports, valves, injector housings, cats & EGR. It's like $100 at most shops around here...well worth the money though. wow, it cleans all of that for 100 bucks? man i'm gonna do that, that sounds like a maintence must......do you know of a general auto chain that does that procedure ← Man, I'm with you Silvermate!!! $100 and it does all that.............crazy good! I mean, you don't have to take anything apart ---it's a dream come true Quote Link to comment Share on other sites More sharing options...
blake918 Posted December 10, 2004 Share Posted December 10, 2004 I had a motorvac service done on my ES300 at a Toyota dealer(something like $120), and I thought it was the biggest waste of money ever. I got my car back, and it ran/functioned the exact same way. No improvements anywhere. My car was dealer maintained for almost all of its life, so maybe that had something to do with it. RW and Silver-I know how you guys keep on top of things, so I wouldn't be suprised if yall got the same lack of results I did. Also, there are several componets to the EGR system. I seriously doubt that the dealer checked every one of them as there are several and are not that easy to check-not doable in the 1 hour diag. they typically give. I had a cel that was giving "excessive egr flow" after changing about 5 parts of the EGR system, I finally found the defective componet(Vacuum Switching Valve- VSV). Quote Link to comment Share on other sites More sharing options...
bartkat Posted December 10, 2004 Share Posted December 10, 2004 MotorVac sounds like some sort of gimmick. I dunno if I would trust the Jiffy Lube guys to hook up and flush and do all that stuff to my Lexus. Quote Link to comment Share on other sites More sharing options...
92Lex Posted December 10, 2004 Share Posted December 10, 2004 Well, some people swear by it. This is like one of those synthetic versus dino oil arguments...everyone has their own opinion about a certain product/service. Quote Link to comment Share on other sites More sharing options...
VGR Posted December 10, 2004 Share Posted December 10, 2004 On another forum with Toyota Mastertechs I asked if Motorvac was a gimmick or a good thing. They said it was OK for partially clogged fuel injectors and also a good profit making device for dealers, BUT with regard to the EGR system they said, quote: "MotorVac will NOT clear out an EGR passage that is clogged shut." Quote Link to comment Share on other sites More sharing options...
92Lex Posted December 10, 2004 Share Posted December 10, 2004 Nobody said anything about an EGR being clogged shut. Quote Link to comment Share on other sites More sharing options...
ECUPirate Posted December 12, 2004 Share Posted December 12, 2004 Have you tried Drano? Run the car down until you have only a 1/2 tank of gas and then add a quart of Professional strength Drano to the fuel tank. ...works great for fuel injectors too! :chairshot: ...oh no, I've been drinking again... "Argghhh, matey!", said the pirate. Quote Link to comment Share on other sites More sharing options...
92Lex Posted December 12, 2004 Share Posted December 12, 2004 Hahaha. When I started to read that post I was thinking "wtf, they make Drano for cars?" I've been doing a little drinkin tonight myself..hahha. Quote Link to comment Share on other sites More sharing options...
hughes369 Posted April 26, 2005 Share Posted April 26, 2005 Hahaha. When I started to read that post I was thinking "wtf, they make Drano for cars?"I've been doing a little drinkin tonight myself..hahha. ← i was told to get mine cleaned out to/ ported, and replace the VSV, how much does this cost for just the vsv valve, and what does the high code 51 mean when refering to air ride suspension. they said that operating relay was over-operating, WTF. thanks for all the advice, later, THE SNAKE 92 LS400 Quote Link to comment Share on other sites More sharing options...
Shaggz Posted April 27, 2005 Share Posted April 27, 2005 I haven't been told to do anything with mine yet. I just know I've got an error code 71 causing the check engine light to come on. All signs point to the EGR system, but how do I determine whether it's the EGR Valve, Modulator, VSV, or what? Do I just go one by one replacing each component hoping to eventually get to the troublemaker? I have inspected the modulator and the filter is nasty and definitely needs replacing, so I guess I'll just start there, but what next if that doesn't solve my problem? Anyone?? One other idea...I have reason to believe my steering rack may be leaking, possibly near the O2 sensor(s). Is it possible that situation could cause faulty O2 sensor operation, thereby causing a misdiagnosed EGR system malfunction? Just a thought... Quote Link to comment Share on other sites More sharing options...
