BeachBumForever Posted December 15, 2018 Posted December 15, 2018 2003 ES300 - 209,000 miles I have developed a "clunk" that seems to be coming from the passenger side trunk area when hitting a pothole or pavement change. First thought is a strut or mount going/gone bad so will probably replace all 4 struts. Need suggestions on whether to use OEM parts or aftermarket parts and sources. I prefer a smooth ride versus performance handling. Suggestions on the parts and process appreciated. Should the struts be replaced BEFORE or AFTER a full alignment? The work will be done by a shop, not by yours truly.
lenore Posted December 16, 2018 Posted December 16, 2018 Struts are discussed all the time, but my choice is KYB struts and OE mounts....Have put them on RX300 and RX400h and a GMC Yukon....Love these struts. the knock noise is probably broken mount, but could also be a damaged stabilizer bar mount.... 1
Lexus Owners Club Posted December 17, 2018 Posted December 17, 2018 following on from what Lenore has stated, in answer to your question....I would carry out a full alignment after the suspension components have been replaced.
