Hello All.
I know the size that's called for in the Pure One filter is the pl20145,but it seems so small? Read some where the Pl 20195 will work too and is larger which I seem to believe is better... Anyone fitted the the larger one ? Any comments? Thanx ;)
Bigger is not better. The factory filter is best and when bought in a package of ten, they cost less than $5.00 each Canadian money. Best deal there is for these engines.
Why mess with some "imitation" filter?
I use the OEM filter on my GS3 since I have 3 vehicles that all use the same filter... however I do know of certain well known users on other forums that do use the larger filters (longer) just because it increases oil capacity slightly.
  • 2 months later...
In tests, the Toyota filter scores as avarage. There are several aftermarket filter that are better, such as MAHLE OC235 (european filter, possibly hard to find at your side of the ocean), that has a larger filter area, though the outer size of the filter can is the same as the Toyota filter. I know that some US brands also scores better than the OEM.
/Råger
Hello All.
HI there,
I have been using the NAPA 1515 which is considerably larger than the factory filter, same flow rate confirmed by NAPA tech person behind the counter. I use royal purple and the NAPA gold 1515.
You may want to do your own research on this to see if this set up will work for you!
Cheers B)
HI there,
Cheers B)
sorry just so u know....the napa tech really doesnt know...they just a part puller truthfully.
Hello All.
HI there,
Cheers B)
Sorry about the last whacked post. I was trying to ask GS in Fla town what year GS he /she has and screwed up :blink:
HI there,
Cheers B)
A lot of the Napa filters (gold) are made by wix....a very good filter.
