Rune04 Posted November 26, 2008 Share Posted November 26, 2008 Hello. I am new here and I have a question that may already have been covered, but I can not find it. My 2001 GS300 headlight lenses are dirty on the inside. Is there a way to clean these or do I need to buy new assemblies? I assume they are not cheap. I appreciate any info you can give me. Thanks Quote Link to comment Share on other sites More sharing options...
sakataj Posted November 26, 2008 Share Posted November 26, 2008 Hello. I am new here and I have a question that may already have been covered, but I can not find it. My 2001 GS300 headlight lenses are dirty on the inside. Is there a way to clean these or do I need to buy new assemblies? I assume they are not cheap. I appreciate any info you can give me. Thanks what do u mean dirty on the inside? like condensation or dirt? cause if you have dirt and trash inside means they leaking and/or car might have been flooded or underwater. sometimes condensation happens from a leak but normally they not DIRTY inside....clarify please. welcome to the club also Quote Link to comment Share on other sites More sharing options...
Rune04 Posted November 26, 2008 Author Share Posted November 26, 2008 Hello. I am new here and I have a question that may already have been covered, but I can not find it. My 2001 GS300 headlight lenses are dirty on the inside. Is there a way to clean these or do I need to buy new assemblies? I assume they are not cheap. I appreciate any info you can give me. Thanks what do u mean dirty on the inside? like condensation or dirt? cause if you have dirt and trash inside means they leaking and/or car might have been flooded or underwater. sometimes condensation happens from a leak but normally they not DIRTY inside....clarify please. welcome to the club also I have had the car since it was new, so I know it has never had any water damage or any other kind. The inside of the lense is hazy, kind of like a window inside the car will get after a while. That's the best way I can describe it. I have on occasion seen moisture inside of them after I have washed it, but it goes away pretty quickly. Quote Link to comment Share on other sites More sharing options...
sakataj Posted November 26, 2008 Share Posted November 26, 2008 Hello. I am new here and I have a question that may already have been covered, but I can not find it. My 2001 GS300 headlight lenses are dirty on the inside. Is there a way to clean these or do I need to buy new assemblies? I assume they are not cheap. I appreciate any info you can give me. Thanks what do u mean dirty on the inside? like condensation or dirt? cause if you have dirt and trash inside means they leaking and/or car might have been flooded or underwater. sometimes condensation happens from a leak but normally they not DIRTY inside....clarify please. welcome to the club also I have had the car since it was new, so I know it has never had any water damage or any other kind. The inside of the lense is hazy, kind of like a window inside the car will get after a while. That's the best way I can describe it. I have on occasion seen moisture inside of them after I have washed it, but it goes away pretty quickly. oh u just mean condensation.....u have a water leak n water is getting into your headlight. might wanna take them off and heat up headlight in the oven (after removing wires/bulbs) and clean the inside lens then reseal them or if you dont wanna take them apart u can just use some caulk on outside if u can find the leak or just caulk whole thing with some clear silicon. or replace whole headlights........ either way Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted November 26, 2008 Share Posted November 26, 2008 before you bake them, try cleaning them up with Meguiars PlasticX. It made a huge improvement on mine and only takes a couple of minutes. Yellowing and haze that appeared to be on the inside were actually removed, especially near the top of the lens. It's worth a shot, if it doesn't work just throw them badboys in the oven. Quote Link to comment Share on other sites More sharing options...
sakataj Posted December 1, 2008 Share Posted December 1, 2008 before you bake them, try cleaning them up with Meguiars PlasticX. It made a huge improvement on mine and only takes a couple of minutes. Yellowing and haze that appeared to be on the inside were actually removed, especially near the top of the lens. It's worth a shot, if it doesn't work just throw them badboys in the oven. u can try that....but i figured if he thought it was INSIDE the lens it really was inside the lens, i mean somedays with my fogsi can see the water in my housing, so you know hence the condensation i get in my fog light.....i need to replace that soon! god im busy/lazy! Quote Link to comment Share on other sites More sharing options...
Rogerm Posted June 3, 2009 Share Posted June 3, 2009 before you bake them, try cleaning them up with Meguiars PlasticX. It made a huge improvement on mine and only takes a couple of minutes. Yellowing and haze that appeared to be on the inside were actually removed, especially near the top of the lens. It's worth a shot, if it doesn't work just throw them badboys in the oven. ---------- PlasticX is great stuff. I would use it even if you don't think you need it. Won't solve water problem though. Quote Link to comment Share on other sites More sharing options...
era57 Posted November 26, 2009 Share Posted November 26, 2009 Hello. I am new here and I have a question that may already have been covered, but I can not find it. My 2001 GS300 headlight lenses are dirty on the inside. Is there a way to clean these or do I need to buy new assemblies? I assume they are not cheap. I appreciate any info you can give me. Thanks I have the same problem. I see a decent amount of condensation in my headlights pretty often. Do I need a new gasket? How do I make this better? Because it honestly looks like crap and I can't stand it. Thanks! Quote Link to comment Share on other sites More sharing options...
locotrucker Posted August 29, 2010 Share Posted August 29, 2010 before you bake them, try cleaning them up with Meguiars PlasticX. It made a huge improvement on mine and only takes a couple of minutes. Yellowing and haze that appeared to be on the inside were actually removed, especially near the top of the lens. It's worth a shot, if it doesn't work just throw them badboys in the oven. ---------- PlasticX is great stuff. I would use it even if you don't think you need it. Won't solve water problem though. I have to agree that Meguiars plasticx is really great for cleaning the lenses. I tried it and I was amazed at how good it worked. I am a firm believer in meguiars products anyway. They have always performed great. Quote Link to comment Share on other sites More sharing options...
vkm Posted June 22, 2019 Share Posted June 22, 2019 Had the same problem. Clean with off bug spray then follow with w-d 40. It worked great on the condensation on my headlights. Quote Link to comment Share on other sites More sharing options...
