Check Engine Light???
Biaggi
Ok, Does anyone know how to diagnose the problem with the Check Engine light? From the owners manual, it states that if the Cehck Engine light comes on it (1) is out of gas or (2) there is an electrical issue. Since I have a full tank, I suspect #2. My LX has 100,600 miles on it and I just recently changed the oil. After about 20 minutes of driving, the check engine light came on. Any help?
Thanks in advance,
:twisted:
Ok Guys... Thanks for the no response... I'd figure there would be a Lexus Tech lurking around, but I'll try to disclose all knowledge I have....
My wife took the LX to the dealer and they stated that this is a common problem with the LX450's. That the catalytic converter registers false readings when in frigid temperatures. He checked the codes and also the cat and verified that all is fine. So he just reset the codes. SOOOO if you have a check engine light come on, it could be the 2 reasons stated in the previous post or a false reading on the cats in cold temps (below 30 degrees ambient) I haven't seen any Service Bulletins or Recalls about this but I believe the service tech at Johnson's Lexus in Raleigh.
C'mon guys... lets make this forum help us!!! Try to post something useful when you find things out!
Thanks,
  • 2 months later...
i had this happen to me this morning, i appreciate your post.
i was looking on the UK posts and it appears that it could be something to do with the fuel cap. i think i will try to reset mine by pulling the fuse.
cheers
:twisted:
Thanks,
i saw your post a bit late. I confirmed with toyota corp. that this is a normal thing with the normal thing in colder area's on the 450's. I also found out that you may be able to resolve this with a new cat. Not sure on the price. You may want to contact Lexus to replace if it becomes an issue.
Hey I just found your post.
I have a 94 GS300 and my check engine came on right after I bought the car from a small independent car lot. It turned out to be an EGR hose which the Lexus dealer fixed for a small fee. This was after I spent weeks trying to get an independent mechanic to fix it. Sometimes the dealer is the way to go.
Good luck!
What is the code? I never run into this problem before. I don't see why the CEL come in when there isn't a problem. They might just want to get you out the door. Get me the code and I will an answer for you.
JPI
  • 3 months later...
You can get a check engine light for any number of reasons. Anything from a bad O2 sensor to an EGR valve. One of the more common reasons is that the gas cap is not on tight enough.
As for false readings from the catalytic converters...I've never heard of that one.
Regards,
Doug
This is a list of the codes produced by OBDII
All of which will cause the Check engine light to stay on.
P0100
MAF Malfunction
P0101
MAF Circuit Range/Performance
P0110
IAT Circuit Malfunction
P0115
ECT Circuit Malfunction
P0116
ECT Circuit Range/Performance
P0120
TP Position Sensor/Switch ‘‘A’’ Circuit Malfunction
P0121
TP Position Sensor/Switch ‘‘A’’ Circuit Range/Performance
P0125
Insufficient Coolant Temperature For Closed Loop Fuel Control
P0130
HO2S Circuit Malfunction, Bank 1 Sensor 1
P0133
HO2S Circuit Slow Response, Bank 1 Sensor 1
P0135
HO2S Heater Circuit Malfunction, Bank 1 Sensor 1
P0136
HO2S Circuit Malfunction, Bank 1 Sensor 2
P0141
HO2S Heater Circuit Malfunction, Bank 1 Sensor 2
P0150
HO2S Circuit Malfunction, Bank 2 Sensor 1
P0153
HO2S Circuit Slow Response, Bank 2 Sensor 1
P0155
HO2S Heater Circuit Malfunction, Bank 2 Sensor 1
P0156
HO2S Sensor Circuit Malfunction, Bank 2 Sensor 2
P0161
HO2S Heater Circuit Malfunction, Bank 2 Sensor 2
P0170
Fuel Trim Malfunction
P0171
System Too Lean (Fuel Trim)
P0172
System Too Rich (Fuel Trim)
P0174
System Too Lean (A/F Lean Malfunction, Bank 2)
P0175
System Too Rich (A/F Rich Malfunction, Bank 2)
P0300
Random Misfire Detected
P0301
Misfire Detected, Cylinder 1
P0302
Misfire Detected, Cylinder 2
P0303
Misfire Detected, Cylinder 3
P0304
Misfire Detected, Cylinder 4
P0305
Misfire Detected, Cylinder 5
P0306
Misfire Detected, Cylinder 6
P0307
Misfire Detected, Cylinder 7
P0308
Misfire Detected, Cylinder 8
P0325
KS 1 Circuit Malfunction
P0330
KS 2 Circuit Malfunction
P0335
CKP Sensor ‘‘A’’ Circuit Malfunction
P0340
CMP Circuit Malfunction
P0385
CKP Sensor ‘‘B’’ Circuit Malfunction
P0401
EGR Insufficient Flow
P0402
EGR Excessive Flow
P0403
EGR Circuit Malfunction
P0420
Catalyst System Efficiency Below Threshold Bank 1
P0430
Catalyst System Efficiency Below Threshold Bank 2
P0440
EVAP Emission Control System Malfunction
P0441
EVAP Emission Control System Improper Purge Flow
P0446
EVAP Emission Control System Vent Control Malfunction
P0450
EVAP Emission Control System Pressure Switch Malfunction
P0451
EVAP Control System Pressure Sensor Range/Performance
P0500
VSS Malfunction
P0505
Idle Control System Malfunction
P0510
Closed TP Switch Malfunction
P0550
Power Steering Pressure Sensor Circuit Malfunction
P1100
BARO Sensor Circuit Malfunction
P1120
Accelerator Pedal Position Sensor Circuit Malfunction
P1121
Accelerator Pedal Position Sensor Range/Performance Problem
P1125
Throttle Control Motor Circuit Malfunction
P1126
Magnetic Clutch Circuit Malfunction
P1127
ECTS Actuator Power Source Circuit Malfunction
P1128
Throttle Control Motor Lock Malfunction
P1129
Electronic Throttle Control System
P1130
Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 1 Sensor 1)
P1133
Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 1 Sensor 1)
P1135
Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P1150
Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 2 Sensor 1)
P1153
Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 2 Sensor 1)
P1155
P1200
Fuel Pump Relay/ECU Circuit Malfunction
P1300
Igniter Circuit Malfunction (Bank 1 Or No. 1)
P1305
Igniter Circuit Malfunction, (Bank 2 Or No. 2)
P1310
Igniter Circuit Malfunction (No. 3)
P1315
Igniter Circuit Malfunction (No. 4)
P1320
Igniter Circuit Malfunction (No. 5)
P1325
Igniter Circuit Malfunction (No. 6)
P1330
Igniter Circuit Malfunction (No. 7)
P1335
CKP Sensor Circuit Malfunction During Engine Running
P1340
Igniter Circuit Malfunction (No. 8)
P1345
VVT Sensor Circuit Malfunction (Bank 1)
P1346
VVT Sensor Rang/Performance Problem (Bank 1)
P1349
VVT System Malfunction (Bank 1)
P1350
VVT Sensor Circuit Malfunction (Bank 2)
P1351
VVT Sensor Range/Performance Problem (Bank 2)
P1354
VVT System Malfunction (Bank 2)
P1400
Sub-TP Sensor Malfunction
P1401
Sub-TP Sensor Range/Performance
P1410
EGR Valve Position Sensor Circuit Malfunction
P1411
EGR Valve Position Sensor Circuit Range/Performance Malfunction
P1500
Starter Signal Circuit Malfunction
P1520
Stop Lamp Switch Malfunction
P1565
Cruise Control Main Switch Circuit Malfunction
P1566
P1600
ECM BATT Malfunction
P1605
Knock Control CPU Malfunction
P1633
ECM Malfunction (ETCS Circuit)
P1645
Body ECU Malfunction
P1656
OCV Circuit Malfunction (Bank 1)
P1663
OCV Circuit Malfunction (Bank 2)
P1780
PNP Switch Malfunction
B2785
Ignition Switch On Malfunction (Immobilizer System)
B2786
Ignition Switch Off Malfunction (Immobilizer System)
B2785
B2791
Key Unlock Warning Switch Malfunction (Immobilizer System)
B2795
Unmatch Key Code (Immobilizer System)
B2796
No Communication In Immobilizer System
B2797
Communication Malfunction No. 1 (Immobilizer System)
B2798
Communication Malfunction No. 2 (Immobilizer System)
Let me know if you want to read these codes without a reader.
Tom
They were posted as Lexus 1996 & Newer OBDII codes, but apparently a few won't be used, Such as the Electronic Throttle control. The rest look good.
I am also wondering about the download command. I will look at the Data on the E1-T buss to see if it looks like the function is available.
i though obd 2 was for 97 and newer
but i know the 94 es 300 1mz-fe engine is also the worlds first obd 2 standard engine
i hope you don't mind as you have this already up i am going to paste it in the tutorial pages for all the codes
as my book has over 52 pages with 25 per page of codes
don't worry i will put them to you credit
  • 1 year later...
More than likely its your oxygen sensor saying your catalyst is bad. This is
because these go out about the 100,000 mile range. There are anywhere from 1 to 4 sensors costing about $100us each. Replace those even if you don't need too because they are about expired anyway and can cut your gas mileage down to half.
Regards
Thanks in advance,
  • 2 months later...
Same thing happened to me. Drove off the lot at a dealer in a 96 lx450 with 109,000miles and the light went on.
When I went to see it, the car was TOTALLY out of gas. We drove directly to a gas station and put some in....but that was about 25 miles before the light went on....
Worried about the car now... it did seem to get really bad gas mileage on the way back...
HOW do you check for the code? Does it have to be at a toyota dealer? I assume you have to plug something in to read what it is....?
  • 4 years later...
:twisted:
Thanks,
I have a 99 Lexus lx 470 and had check engine light come on once when I didn't tighten the gas cap all the way and second most recently but it not the gas cap. I had a diagnosis of bad O2 sensor which was replaced. The check engine light was off for about 3 days but has recently returned. I think that it is the cat. coverter, but it doesn't seem to be causing a problem at this point so I give.
