thesaintjim Posted July 30, 2005 Posted July 30, 2005 My Solara and 4Runner both have the gauge that displayed how many miles were left before I was empty (not including the reserve). Does the 400h have that? I can't seem to find it at all and that fuel gauge is so small.
katzjamr Posted July 30, 2005 Posted July 30, 2005 The only thing i have read is you have about three gallons left when the low fuel light comes on. I am sure you have been told it is critical to NEVER run out of gas in this vehicle so its a good idea to get in the habit of refueling sooner than you would in a conventional SUV.
91L3xus Posted July 30, 2005 Posted July 30, 2005 I was checking out the dashboard of 400h's today, and saw that there isn't a tach. Why is that? Only a gauge to show the use of the hybrid system.
uthorns1976 Posted July 30, 2005 Posted July 30, 2005 I was checking out the dashboard of 400h's today, and saw that there isn't a tach. Why is that? Only a gauge to show the use of the hybrid system. ← I commented on the 400h's instrumentation a while back. I think the Kw gauge is a waste. I guess it was easy for Lexus to replace the tach with the Kw gauge and go on down the road. They could have come up with a lot more useful gauges than Kw (oil pressure, etc.). But, I don't want to start another thread on the 400h's shortcomings. ;)
RX400h Posted July 31, 2005 Posted July 31, 2005 I was checking out the dashboard of 400h's today, and saw that there isn't a tach. Why is that? Only a gauge to show the use of the hybrid system. ← Does any of the hybrids have a tach? It may be totally unnecessary if the vehicle utilizes a CV transmission. The KW gage is like a boost gage - more entertaining than necessary.
91L3xus Posted July 31, 2005 Posted July 31, 2005 Does any of the hybrids have a tach? It may be totally unnecessary if the vehicle utilizes a CV transmission. The KW gage is like a boost gage - more entertaining than necessary. ← Don't know about the Highlander, but Honda's do. What if high RPM cruising was a problem area in the Hybrid as it was in the RX300? How would one be able to figure that out? Here's a Civic Hybrid dash:
Philly400h Posted July 31, 2005 Posted July 31, 2005 I use it to see which braking methods produced the higher charge. With it, I've been able to figure out that subtle braking methods can really make quite a difference in battery recharging - dipping into the blue farther for different distance/speed/brake pressure. I'm not sure how much I'm benefitting in the grand scheme, but it certainly must help, and is fun too. I must agree that a tach would have been good, and they could have the smaller kwh guage next to it.
indiasfinest Posted August 1, 2005 Posted August 1, 2005 ive never seen the dash on an H can some body post pics...thanks
LexKid630 Posted August 1, 2005 Posted August 1, 2005 you know i've always liked the bright white gauges with the tinting plastic so it gives it that "look", but i think they needed a change for the hybrid. They could have made them blue maybe?
thesaintjim Posted August 1, 2005 Author Posted August 1, 2005 hrm, we sorta got off the subject, heh. Does this car have the gauge that displays how many miles left before fillup?
bainse Posted August 1, 2005 Posted August 1, 2005 I don't think it does - don't see it in the manual. lexus probably omitted it on purpose, so drivers are prompted to refuel when the gauge is approaching empty, rather than reasoning that they still have [x] gallons left.
indiasfinest Posted August 1, 2005 Posted August 1, 2005 i couldve gone 2 lexus my self but after several reports of the pics being diff. than real life i thought some of u may have your H dashpics on hand so 4get it...
JasonATL Posted August 1, 2005 Posted August 1, 2005 No. It does not indicate anywhere (gauge or trip info) how many miles until you are out of fuel. Just a standard fuel gauge.
patt Posted August 1, 2005 Posted August 1, 2005 i couldve gone 2 lexus my self but after several reports of the pics being diff. than real life i thought some of u may have your H dashpics on hand so 4get it... ← That picture looks the same as my dash. The thing that the Lexus pictures don't show well is the exterior colors. I think the idea of the kW guage is okay, but the execution could be improved. In theory, I don't mind having it instead of a tack. In any high power output situation, a lot of the power will be coming from the engine so its position should be somewhat proportional to how hard the engine is running. Like Philly, I find it useful for guaging my braking pressure. In particular, I watch for the point where pushing harder on the brake doesn't move the needle more since that means the pads are providing the additional braking. In the other direction, point where it goes from the dashed area around the zero to the solid is the point where it will usually turn the engine on (though if the batteries are low or during initial warm-up it may turn the engine on sooner). What they did wrong, IMO, was to have so little resolution on the guage. As you can see from the picture, only 3 numbers are marked on it (and only the 100 even has a tick on the circle - the 0 and the 200 are just fuzzy locations). Also, in the same space they could have added some indication of how much of the energy was coming from the engine versus the motors which would give a closer idea of how fast the engine is having to turn over.
thesaintjim Posted August 1, 2005 Author Posted August 1, 2005 No. It does not indicate anywhere (gauge or trip info) how many miles until you are out of fuel. Just a standard fuel gauge. ← Thanks. My dealership just confirmed that too. Thanks again for your help guys/girls
LexKid630 Posted August 1, 2005 Posted August 1, 2005 does anyone else think they should make everything digital? Like instead of having gauges, just have a readout of speed etc? What century are we in already? LOL
katzjamr Posted August 1, 2005 Posted August 1, 2005 I find digital readouts irritating to look at and gauges much more pleasing to the eye. My friend has a GM digital speedo on her Buick and i hate it.
lexus411 Posted August 1, 2005 Posted August 1, 2005 there is no miles to empty gauge based on the variation of mpg in this truck.
LexKid630 Posted August 1, 2005 Posted August 1, 2005 I find digital readouts irritating to look at and gauges much more pleasing to the eye. My friend has a GM digital speedo on her Buick and i hate it. ← didn't think of that; the numbers constantly changing etc..
uthorns1976 Posted August 2, 2005 Posted August 2, 2005 Does Lexus ever ask average Joes like us what we think about cars features before they put them into production??? Example: 400h--kW gauge, no satellite radio, poor choice of colors, etc.
jerryray Posted August 2, 2005 Posted August 2, 2005 Does Lexus ever ask average Joes like us what we think about cars features before they put them into production??? Example: 400h--kW gauge, no satellite radio, poor choice of colors, etc. ← True, the Gauge, I don't care about but would like a dual needle/tach. Miss my Breakwater blue, Had to install my commander XM radio. Things are well now. Perhaps there will be an firmware update to help some mileage issues.
indiasfinest Posted August 4, 2005 Posted August 4, 2005 is it possible to get an after market dash? especially on an H?
benfb Posted August 30, 2005 Posted August 30, 2005 does anyone else think they should make everything digital? Like instead of having gauges, just have a readout of speed etc? What century are we in already? LOL ← I'll vote for digital. My 1994 Cadillac Deville has digital, and I like it a lot better than the gages on the 400H (although I think the 400h is still a great car!).
