Hey guys. Just purchased a 1997 LS 400 and it's seen better days. It's leaking coolant pretty badly and I need to know what all the hoses are so I can start replacing the ones that I know are bad. It's also got a Heater Control Valve that's been broken off so I'll probably have to replace that first. Basically I need a manual like a Haynes or a Chiltons but I'm a cheapskate and was hoping someone might know where to get the PDF version of the manual.  If not links to the manual could anyone give me pictures of the pages I need just to show me what exactly the parts are called I need to replace. This might be a stupid question also but it's low on Automatic Transmission Fluid and I wasn't sure if I can add it by pouring it directly into the place the dipstick is held. I can't find an opening to add it besides that and I know sometimes adding transmission fluid isn't as easy as topping off your oil or coolant. Any advice is appreciated. Thanks guys.
Sign up for a 1 day account and download the whole repair manual. It only costs $15 for the day.
  • Like 1
Yes, pour trans fluid directly into the dipstick pipe, whatever its name is.
  • Like 1
If you're draining the transmission from its oil pan, one gallon or so of ATF will fill it back up.  Be sure to use only fluid that meets T-IV/3309 specification and follow the right procedure to check it.
Paul
  • Like 1
