psckrat Posted February 21, 2004 Share Posted February 21, 2004 I have 1992 SC400 taht has a dark area on the right hand side of the Climate Control display. I believe it may be a lamp. Obviously you have to remove the entire console area to replace it. Anyone have any other ideas Quote Link to comment Share on other sites More sharing options...
2XLexV8 Posted February 21, 2004 Share Posted February 21, 2004 Hello, Is the display itself dark, or are the lights just not working? The lights are the least expensive. The display can be several hundred, depending on if you can get just the LCD replaced, or find a good panel somewhere. My display and lights are out. Price tag around $350 to repair Good luck Quote Link to comment Share on other sites More sharing options...
psckrat Posted February 22, 2004 Author Share Posted February 22, 2004 Display appears to be ok. Entire display looks ok in daylight. Only when lights are on does it appear dark Quote Link to comment Share on other sites More sharing options...
UCF3 Posted February 22, 2004 Share Posted February 22, 2004 I would suggest you visit "Performance Parts, and FAQ" pinned in this forum. I've placed a post for some remanufacturers, but expect to pay a little--Not $400. If that one bulb doesn't really bother you, I would suggest leaving it for now, until you really need to. Quote Link to comment Share on other sites More sharing options...
hershy67 Posted February 22, 2004 Share Posted February 22, 2004 Hit the darkened area with the palm of your hand. Seriously, that's how I solved my problem. Quote Link to comment Share on other sites More sharing options...
moemoe_xp Posted February 24, 2004 Share Posted February 24, 2004 i have the same problem i think it's the ink in the screen, u have to change the Screen or buy a new AC display. i found in Canada for 300$ CND Quote Link to comment Share on other sites More sharing options...
Bandit Posted March 12, 2004 Share Posted March 12, 2004 I have a 93 SC400 and have the dreaded LCD Bleed. I found one on Ebay from a 95 SC300. The LCD is amber instead of Green and I got both the Climate Control Unit and the Radio Head Unit. The 93s had green lights in both LCDs, so now I'm amber and it is very bright. Now I can see all the symbols. To bad no one repairs these, they repair the radios and they repair the LS units, but not the SC units. Quote Link to comment Share on other sites More sharing options...
OKSC3 Posted March 12, 2004 Share Posted March 12, 2004 What kind of light is used in the display? LED? Quote Link to comment Share on other sites More sharing options...
LLS Posted March 12, 2004 Share Posted March 12, 2004 To bad no one repairs these, they repair the radios and they repair the LS units, but not the SC units they do repair these, and everything else involving an SC. http://www.lextech.org/ Quote Link to comment Share on other sites More sharing options...
Bandit Posted March 12, 2004 Share Posted March 12, 2004 LLS, I'll say again, Too bad no one repairs these! Currently there is no one that can repair the LCD Bleed that is common with the SC Climate Control Unit. Burned our lights are repairable, but the LCD Bleed requires the replacement of the Liquid Crystal Display and currently, no one offers this for the SC Climate Control Unit. The closest I came to getting one repaired was when I contacted an individual that repairs these units for the LS model and he offered to sell me 100 LCD screens and I go into business to repair other forum users. About $8,000 for these units. Quote Link to comment Share on other sites More sharing options...
LLS Posted March 12, 2004 Share Posted March 12, 2004 I see, i was speaking of the OP's question. Display appears to be ok. Entire display looks ok in daylight. Only when lights are on does it appear dark while responding to you at the same time. The LCD (liquid crystal display) is filled with liquid crystal (surprise). When the seal starts to leak air around the edge of the climate's LCD, the screen takes on air. The air dries out the liquid crystals and they turn black. Heat and cold make a dramatic impact on the units. someone in a warm climate may not see this problem for up to a year after it initially begins, whereas someone in a cold climate will see it almost immediately. I have experimented with trying to saturate the lcd with various materials, but have yet to find something that will work. This is going to be one of those things that get's replaced if it goes bad, like a pair of brakes. Quote Link to comment Share on other sites More sharing options...
OKSC3 Posted March 12, 2004 Share Posted March 12, 2004 Well could you go in with one that works and seal it with RTV or something to help prevent it from bleeding. Quote Link to comment Share on other sites More sharing options...
OKSC3 Posted March 12, 2004 Share Posted March 12, 2004 (edited) Oops, wrong place... Edited March 12, 2004 by OKSC3 Quote Link to comment Share on other sites More sharing options...
LLS Posted March 12, 2004 Share Posted March 12, 2004 In theory, yes. In reality you are only delaying the inevitable by a minimal margin. There is a certain amount of natural drying going on that is unavoidable. glass is a great insulator, but not without some leakage through the very glass itself. your efforts probably wouldn't be well rewarded. Quote Link to comment Share on other sites More sharing options...
Bandit Posted March 13, 2004 Share Posted March 13, 2004 The 1993 Climate Control Units were notorious for leaking/bleeding and fading to black. This has not been the case with other year models. But any model year 300 or 400 from 92-95 will work. The 95s went to an amber lighted display. Quote Link to comment Share on other sites More sharing options...
RoyBoy Posted January 23, 2005 Share Posted January 23, 2005 I have 1992 SC400 taht has a dark area on the right hand side of the Climate Control display. I believe it may be a lamp. Obviously you have to remove the entire console area to replace it. Anyone have any other ideas ← I have the same problem with my 1993 SC 400. I haven't tried to fix it yet for fear of doing some damage. Did you get information on how to remove the console area without damaging it? Could you email me the info. at Aargau@cox.net Thanks :D Quote Link to comment Share on other sites More sharing options...
Vegassc400 Posted January 23, 2005 Share Posted January 23, 2005 If anyone is looking for help to remove thier gauge cluster check here. Great write up with pics. http://www.lexuspros.com/tutorial7.htm Quote Link to comment Share on other sites More sharing options...
jakino3388 Posted January 23, 2005 Share Posted January 23, 2005 I have 1992 SC400 taht has a dark area on the right hand side of the Climate Control display. I believe it may be a lamp. Obviously you have to remove the entire console area to replace it. Anyone have any other ideas ← I have one for sale everything is working let me know if you need it. jakino Quote Link to comment Share on other sites More sharing options...
haiku Posted January 24, 2005 Share Posted January 24, 2005 If anyone is looking for help to remove thier gauge cluster check here. Great write up with pics.http://www.lexuspros.com/tutorial7.htm ← jakino, I'm interested. What's your phone number. I'm also in Hawaii. Quote Link to comment Share on other sites More sharing options...
jakino3388 Posted January 25, 2005 Share Posted January 25, 2005 If anyone is looking for help to remove thier gauge cluster check here. Great write up with pics.http://www.lexuspros.com/tutorial7.htm ← jakino, I'm interested. What's your phone number. I'm also in Hawaii. ← call me at 265-9252. also have injen intake and 19' rims the one in the pic. kino Quote Link to comment Share on other sites More sharing options...
