Interchangeable Wheels
w140amg
Which Lexus model wheels are internchangeable with the 95 LS400?
I assume all LS400 wheels are...but what about others such as GS or LS430, etc.
Thanks
only 95+ LS400/430 wheels are interchangeable due to the massive front brakes on the 95-00 LS400 and all LS430s. any 89-94 LS wheels will NOT fit.
IS, SC, ES, and RX wheels will not fit at all, neither will 1st or 2nd gen GS wheels (up until 2006). 3GS (06+) wheels will fit DEPENDING on year, size (generally only the 18" wheels) and if they came off of a 430/460 or a sport packaged 350.
Also, 88-98 Supra Turbo (that's mk3 and mk4) wheels will fit and clear the brakes (although the mk3 turbo wheels are imho ugly as sin) and the 18"s off of the LS430 are a popular upgrade.
I'm confused. (Seems to be a recurring condition with me) I have a 94 LS400 with 16" wheels and a 04 LS430 with 18" wheels. If I upgrade the 04's wheels, can I put the old 04's on the 94 or will the brakes get in the way? Talked to one supplier and they alerted me to this problem and said I could not do it but your response seems to say that this could work. Thanks for your help.
Yes, you can put 18" LS430 wheels on a 94 LS400 but you can not put 16" 94 LS400 wheels on an LS430. The supplier you spoke with is wrong.
Im sure someone has asked this and had it answered on the forum so I apologize in advance for being repetitive.
Can the 18" LS 430 wheels that were available after '04 be used on a 2001 LS 430?
04 and 01 are the same exact car.
all 95-00 LS400 and all 01-07 LS430 wheels are interchangeable among those model years.
Thank you much Puredrifter. Just wanted to be sure.
Should have taken the car in for a service inspection before buying it.
Two struts are bad and have oil coming out of valve covers and pan.
I understand struts cost upward of 1,100.00 each to replace, is that what the going rate is? Any suggestions?
that is only true for the air suspension equipped cars. you can convert to a conventional spring/shock setup for under 600-800.
This list should be of interest. All of these wheels interchange.
Lexus
1990-2000 LS400
2001-2006 LS430
1992-1999 SC300
1992-1999 SC400
2002-2008 SC430
2007-2008 ES350
1993-2006 GS300
2007-2008 GS350
1998-2000 GS400
2001-2008 GS430
2006-2008 GS450h
2001-2005 IS300
2007-2008 IS250
2007-2008 IS350
Toyota
2007-2008 Camry
2007-2008 Solara
2005-2008 Avalon
2004-2008 Sienna
that list makes no sense. It is just a list and if taken at face value it makes no sense.
As previously stated by PD 95 and up LS wheels are the only ones that fit those cars. The same 95+ LS wheels will fit on any other Lexus but not the otherway around .
