sainikai Posted September 12, 2003 Share Posted September 12, 2003 I never had problem with audio antenna. Recently, I noticed that antenna was not all the way down. I have no clue how to repair it. Please guide how to replace it and how much it is going to cost me. Thanks. Quote Link to comment Share on other sites More sharing options...
VMF Posted September 12, 2003 Share Posted September 12, 2003 i dont know it might be only my experince but aftermarket antennas brake like crazy. so what i did is i just cut the cable and now i pull it out manually. i know sometimes its embarrasing but i dont wanna pay 90$ for the antenna or 300$ for the whole assembly. in your case you can extend the antenna. spray it with WD40. wipe it. do it couple of times and it might help. you can use liquid wrentch as well. its either dirty or bent. Quote Link to comment Share on other sites More sharing options...
oversteer Posted September 12, 2003 Share Posted September 12, 2003 Has anyone tried the antennas on Ebay? There are several different models being listed. One of them is 39.50 and claims to be a german made OEM manufacturer. I was just wondering if anyone had tried it. item=2432093327 Thanks, Chet Quote Link to comment Share on other sites More sharing options...
tansupplyman Posted September 13, 2003 Share Posted September 13, 2003 attached '93 shop manual instructions regarding antenna. page 1 here---pg 2 on next one Quote Link to comment Share on other sites More sharing options...
tansupplyman Posted September 13, 2003 Share Posted September 13, 2003 page 2 Quote Link to comment Share on other sites More sharing options...
tansupplyman Posted September 13, 2003 Share Posted September 13, 2003 print out to read better; kb's limited here. Quote Link to comment Share on other sites More sharing options...
obergc Posted September 13, 2003 Share Posted September 13, 2003 You just probably need a new mast, I purchased one from Lexus of St Louis for around $55. Easy replacement job. I would expect that you will have to remove the entire antenna unit though because the toothed nylon cable that runs internal to the mast that extends and retracts the mast is probably broken off and most of the cable is inside the antenna housing. Not an expensive or a hard job to repair using Lexus parts. Curt Quote Link to comment Share on other sites More sharing options...
mapman Posted September 13, 2003 Share Posted September 13, 2003 you can pick up a new mast from irontoad.com for $38. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted September 13, 2003 Share Posted September 13, 2003 i am sure when i replaced my mast on my es it was only 30 something $ about 4 years ago as i thought it wasn't extracting fully until i installed the new one and found it is just he way some of the masts heights are different which i alo bought form lexus Quote Link to comment Share on other sites More sharing options...
