Tire Pressure Sensors
My IS-350 has pressure sensors in the wheels. If I calibrate the sensors to 35/37 PSI (standard inflation) how much can the pressure drop before the warning light comes on? My dealer indicated that they reset the sensors to 27/27 to reduce the number of alarms - but I want to keep the pressure correct.
i think that problem with the sensors are that they dont detect anything if very very small amounts of aire come out slowly. It will only tell you something if the pressure drops all of a sudden, like a blown tire.
well that makes no sence at all. If I blow a tire, I don't need some little sensor to tell me the tire instantly went flat. I thought these sensors or systems were to tell you when the pressure drops gradually over time. For example if I had a slow leak due to a nail or faulty valve stem.
Dave, what is said in the manual?
steviej
People have reported the tire pressure warning coming on around 25-26 PSI.
So, if the tire pressure sensors are calibrated to 35 PSI, it takes a 10 PSI drop to have the alarm come on? That seems to be a big drop - this car can run at 100 MPH easily - I would not want to run at 80+ with the tires inflated to 25 PSI. I'm going to see what the dealer says......
David
David
Beats not having any sensors at all. They probably don't expect you to run at sustained speeds of 100 MPH anyhow.
David
I have an IS 350 my tire sensor went off yesterday. My driverside rear tire was down to 30psi. I had been told that a 5psi drop will activate the sensor. The sensors are not as sophisticated as my prior vehicle an Audi Allroad which identified the specific tire when the psi droppped.
My tire sensors went off day before yesterday, it was down to like 25 30 something like that. As soon as I got into the car they went off, I think they do a good job. But I have no idea how the pressure dropped that far so suddenly on all four tires....
  • 1 year later...
This may be a dumb question, but I had my tires replaced (2005 LS430) from a "non-dealer" source and I'm wondering: did they reinstall the tire pressure sensors? My understanding is that the sensors are actually a part of the air valve...should I be concerned and am I even considering this correctly?
Many thanks...
LVB
The sensors are great. Both times they went off I thought false alarm because tires looked fine. Wrong both times nails both times. In fact the first time it was so small without a head the dealer didn't see it unless the sensor went off again. Since I drive 100 miles a day they saved me from being stuck on the side of the road both times.
Many thanks...
LVB
The sensors stay in the wheels. If you don't have an alarm then they are ok.
David
Just like you may not want to wait until your oil light comes on, just because you have a TPMS doesn't mean you shouldn't still manually check your tire pressure. Personally, I would not want it coming on for 1 or 2 PSI change.
David
Actually, the FM states that if you will be driving at high speeds (~100MPH), you should increase the tire pressure. I think is was about 7-9psi above the normal specs of 35/37psi F/R.
So with the higher pressure as the TPMS reference. A 10psi drop would put the warning pressure at around 35psi.
Regards,
Many thanks...
LVB
Bartkat - thanks for the information; I was worried that I lost my sensor capability. No alarms, but I will go check the air after work...
Thanks
LVB
Many thanks...
LVB
Thanks
LVB
I had 4 tires put on with no sensor problems. Then I adjusted the PSI in the tires to what I wanted and everything is just fine.
Many thanks...
LVB
Thanks
LVB
Lexus told me the tire pressure changes with the weather winter/summer (cold/hot)
Many thanks...
LVB
Thanks
LVB
I would second that... here in Texas, we occasionally have wild swings in temperature (from HOT to COLD) in a day. I've had tire pressures drop 6-8 psi in a matter of hours, causing the sensor to light up.
If they were to come on for a 1-2 PSI change you would get a lot of "false" alerts in the winter. Assuming you live where there actually is a winter. Subfreezing temperatures can lower a tires PSI and your monitor will go off until friction increases the PSI while driving.
