Sluggish When Cold
Lex3486
You really shouldn't be hard on it until it's warm. The trannies hydraulic fluid works better when warm, the heads and block have expanded and are tighter when warm.
It's a problem on supercharged and turbocharged cars, if you get to hard into the boost when cold you can blow head gaskets really easily.
Just be easy before she's warm.
Cheers,
Aaron
10 minutes is for your idle to go from high all the way down to 650 is normal isn't it? I wouldn't suggest letting your car sit there for 10 minutes idling every single time though. Just do what barkat suggested and swap out your thermostat.
ill do that but is that an easy job?is it expensive?
Drain about 1/2 gallon of coolant from your radiator.
Follow the radiator hose back to the block and there should be a metal housing that the hose is attached to.
There's usually 2 screws that hold the thermostat housing in place...remove those 2 screws and you should see the thermostat.
I can't really see which hose leads to the thermostat in the picture though. I wouldn't really be able to tell you exactly which parts you need to remove unless you give me more pictures. Maybe someone who has an SC3 can chime in.
Take some pics from the driver side of the car.
