sjc6765 Posted November 21, 2004 Share Posted November 21, 2004 does anybody know how to get the little rubber bumbers that are under the center arm rest? Mine are missing causing the arm rest to bounce up and down. Quote Link to comment Share on other sites More sharing options...
Lex3486 Posted November 21, 2004 Share Posted November 21, 2004 Same here... Quote Link to comment Share on other sites More sharing options...
BlurrySC300 Posted November 21, 2004 Share Posted November 21, 2004 These can be found at your Lexus dealer. I think a pack of them (4 or 5) goes for about $5....easy to install and last for about 5-6 months...at least, thats for me. Hope this help --Taylor Quote Link to comment Share on other sites More sharing options...
JDOwen2 Posted November 22, 2004 Share Posted November 22, 2004 I used the little bumpers from kitchen cabinets. Lowe's or Home Depot. Quote Link to comment Share on other sites More sharing options...
Mr. Curious Posted November 22, 2004 Share Posted November 22, 2004 i used little black globs of silicone. B) Quote Link to comment Share on other sites More sharing options...
KY3TS Posted November 23, 2004 Share Posted November 23, 2004 little clear bumpers for kitchen cabinets as stated above, work great. mine have lasted six months and still there. Quote Link to comment Share on other sites More sharing options...
knmaynard Posted November 23, 2004 Share Posted November 23, 2004 little clear bumpers for kitchen cabinets as stated above, work great.mine have lasted six months and still there. ← Same here, $1.98 at Target, and they fit perfectly. You can't see them at all, and it kept the stupid thing from rattling every time I put my elbow down on it. The spacing is perfect, closes tight but not too tight. Quote Link to comment Share on other sites More sharing options...
Lex3486 Posted November 23, 2004 Share Posted November 23, 2004 So obviously this is a common problem haha Glad to see my car is normal. What about cracks on the door panels? Any takers on that one and how to fix them? Quote Link to comment Share on other sites More sharing options...
Bandit Posted December 9, 2004 Share Posted December 9, 2004 If you are talking about the crack that appears where the pull handle attachs to the door panel, this is another common problem. The molded panel and attachment points to the door were not strong enough to handle the heavy weight SC doors. The plastic cracks and now there is some movement in the door panel when you pull the door shut. This is very common to the drivers door as it is used more. To fix this, you must remove the door panel and reinforce the cracks with epoxy. I also fabricated a sheetmetal brace to reinforce this area. You will understand what I am talking about when you remove the door panel and look at the inside and see the cracks. Hope this helps! Quote Link to comment Share on other sites More sharing options...
