I have a 92 ES 300, and I've tried using the ECT before. I noticed it gives some better acceleration, but how do you guys use it? Do you leave it on all the time, or only turn it on when you're accelerating quickly?
I heard it wastes alot of gas and puts alot more wear and tear on the transmission. Is this true?
What exactly does it do?
Thanks.
It's Electronically Controlled Transmission - basically a computer controls when the car changes gear. In "Power" mode, the car changes gear at higher revs - which makes you accelerate quicker, but uses more gas.
I generally leave mine in normal, and put it into power if I need to overtake in a hurry.
I have a snow mode on mine too.
HTH
the ECT only tells the transmission to shift at higher rpm's. since the max hp and torque is around the 4400rpm area, the max power isn't in the lower rpm's.
allowing the engine to run into the higher rpm's gives you full power. sure it uses more gas since you're in higher rpm's, but when you're in a hurry. it helps. i usually keep it in normal, unless someone challenges me that i might need some help on, or i'm in a hurry to get to school.
as already expalined
ect is just a button
it really does nothing
you dont already do
pin the pedal and it will shift higher, with or without the button
try it,same rom shift point ,when throttle is wide open
it is ony for moderate driving where someone might feel the car is under powered,all the time
mine is off
i don't waste my time using it
agree w/ skperformance. if you shift hard most of the time and accelerate aggresively, your car will start to shift at later points anyway. One interesting thing to note, however, is that before my tranny died on me, it felt like the gears were slipping between shifts (hard to describe). Putting the car on ECT mode was the only way i could prevent this feeling.
first thanks
for the reinforced point mezoom
especially from such a well known es mod
second the only thing i can think that kept it from slipping by using the ect button
is that the power or torque curve would drop at higher rpms causing less slippage when released
was it a thuding kind of noise?
my work truck does this all the time when put into reverse and i am still on the gas
but it is a 2001 dodge caravan,what should i expect lol
sounds like the valve body and check balls in it where sticking causing the clutch plates to not disengage fast enough, thus slipping before the next gear could be issued by the learing of th valve to the next set of clutches
if that helped to bypass the problem
i really do feel bad for the new owner of that car
but i am sure the dealer is getting stuck with the 30 day warrenty atleast
nice to see you still have time
even with your new scooby
are you going to take the sti version out for a trip yet?( if it is avail yet)
