When I'm driving my 92 ES300 over 45-50 mph with all the windows closed I hear a lot of wind rush. Can somebody tell me what I can to do minimize this problem? Thanks.
That was always a problem with the earlier ES's and that's why they finally changed the door insulation design in the '02 ES. Sorry I can't help you but maybe somebody out there came up with a solution. :unsure:
Alan
Has anyone tried putting on a fresh uniform layer of silicone adhesive over the rubber insulation? How about a thin layer of silicone grease?
What happens is the window seal rubber dries and cracks, creating wind gaps. Amf is right about why the ES now is a solid door more or less. Basically the only way to fix this permenantly is to replace the seals, which really isnt that big a deal actually.
I always had this problem with my 1994 Lexus even when it was brand new and the dealer never corrected it! I even read writeups in 1994 about this model having the wind noise problem so I don't think it was caused by dried up insulation. :)
Alan
between here and CL, the solution is the same. People just replace the rubber seal/gasket with a brand new one. DIY.
sj
the solution isn't usually the gasket
press them ,do they feel soft still?
if so then it isn't the gasket at all i learned the hard way i bought new ones for both sides an it was no use
the seal between the glass and gasket is not sealing
using the silicone spray will help alot
the other more permanent way is to have the glass on inside the door adjusted so it is against the gasket again
the biggest problem is people closing the door by the window not the door handle causing it to go out of alignment and causing a leakage of air
also silicone spray the sunroof also and trunk as air will whistle anywhere it can
don't forget the rubber edges around the doors and body
try the silicone first as adjusting the window glass is a pain in the !Removed!
any brand of spry will work no real differences
also i used to use and still do use
meguires endurance tire finish
it keeps the rubber perfect and has a nice slightly tacky feel so it seals even better than the silicone which is thinner and is better for simple edges
  • 10 months later...
I have a 1999 ES300 and I recently took this to the dealer to fix my "windrush" issue. It certainly was not a cheap fix and it took about 3 hours to perform. Basically the dealer replaced the upper window seal. the black plastic piece that goes in between the windows and the mirror bracket mount. The ES300's of this era (97-2001) will always have a small amount of windrush due to the frameless design of the windows. This fix that the dealer performed did make a noticeable difference in the amount of windrush i get. I only did this on the driver side. I will be doing the same thing to the passenger's side soon.
did it take 3 hours to replace the gasket or to adjust the windows. If it was just the gasket you got hosed. I removed mine tonight within 3 minutes and replaced it within 10 as it is a tongue and groove fit with pins at the middle and ends.
Really? I have never noticed it in mine, a 1997. It's very quiet at highway speeds. My Acura Legend coupe is also a frameless design, and it's almost as quiet as the Lexus. I'll pay more attention to it from now on, I guess...
I guess it's to be expected since the 92 - 01 had the frameless design. I agree you can hear a slight windrush as speed climbs, but nothing at all serious as I can hear the stereo withour having to crank the volume & no problems having a normal conversation with passengers. Actually mine is quieter than my Maxima with the window frame.....go figure. :lol:
:cheers:
The wind noise problem is expected on all pre-'02 ES models. I still get a little wind noise on my '01 ES, but not too much to make me go nuts. I guess the nice thing about the frameless window design is more convenience of entering/exiting the vehicle :D
Skperformance,
I need to replace the window gasket, too. Could you either give more detail on how to remove and install the gasket or provide me a pointer to where I can find such instruction? you really think it's DIY? do you even know how much it costs for 97 ES? thanks alot
For my 94 it only needs to have a new one orderred i think i paid 120 -160 a side ,it was years a go i did it. You basically start at one end and pull it away from the car it will release the plastic plugs and then the rest of the rubber is held in a metal bracket just keep pulling it out. More clips on the back of the A ,B and C pillars just look at the new one to see where they are . It is just the reverse to install. Just feed the tounge and groove rubber back in ,all done in an hour for the first side and 3-5 minutes for the second when you realize how easy it really is.
The 3 hours was for window adjustment, mirror bracket replacement, center trim piece replacement and testing. It seemed like an involved ordeal, but thanks for the tip on replacing the one on the other side by myself.
I experience the same on 98 ES300, Seems to me two places on driver side as other said: Near Glass and from Door jams. I have tried to treat rubber seals they are soft and don't think seals causing the wind rush.
Lex,
Let me know if you are successful with any of these recommendations. Thanks
Suggest you clean and polish (wax) the door frame where the seals meet the metal, then use a good protectant on the seals. That should help to dininish the windrush that is apparently inherent in the original design. And turn up the volume on your stereo.
I have to get my passenger front door adjusted as the top of the window is "catching" the moulding when opening & closing the door.......just makes an odd sound & you really notice it when you do it slowly. I just got the windows tinted so I hope the dealership dosen't screw my tint job up whtn they adjust it (under warranty). :blink:
:cheers:
NO NEED TO REPLACE ANYTHINK. FIRST REMOVE THE SIDEVIEW MIRROR,
NEXT SQUEEZE THE TRIANGLE RUBBER WINDOW GUIDE SLIGHTLY
WITH PLIERS TO CLOSE THE GAP ENOUGH SO THE WINDOW WILL
FIT TIGHTLY,NEXT BEFORE REINSTALLING THE MIRROR RUN A SMALL BEED
OF BLACK SILICON ON THE SURFACE THAT THE MIRROR WILL SIT ON ,NEXT
ONCE THE MIRROR IS ON THE CAR, TURN THE BREAKAWAY MIRROR UNITL IT IS AGAINST THE DOOR,FILL THE GAP BETWEEN THE MIRROR HOUSING AND THE ACTUAL MIRROR WITH FELT TAPE.....THIS IS THE ONLY REAL FIX, AND IT IS ONLY A BANDAID UNTIL IT STARTS AGAIN. ALSO DON'T FORGET, ALOT OF THE NOISE IS WIND TURBULANCE BOUNCING OFF OF THE GLASS AND IS NORMAL ON ANY CAR...UNFORTUNATLY YOURS DOES'NT HAVE WINDOW FRAMES TO BLOCK THE NOISE
how difficult to install wind deflector for ES 300 moonroof ? which is the best place to buy deflector ? Need mechanic assistance or can be done by ourselves ?
the moonroof deflector is a DIY and you can get one for short money on www.irontoad.com
It should come with instructions.
steviej.
