Latest Posts
Showing topics posted in for the last 365 days.
- Today
I have a 2024 Lexus TX500h Luxury and drive both freeway and city. The best and average I a seeing is 21.4 MGP. I took it in to dealer and they hooked it up and said it is running properly. With the advertised MPG at 27/28 that is 20% below expected and most of the time even driving thought parking lots is in gas mode. Looking at the TX350 Luxury is rated at 21/27. Is there anyone with the same problem?
- Yesterday
Did this just happen all of a sudden ? No previous lights on the dash ?
Thanks for confirming that there isn't any set tightening order. I just did a crisscross pattern with gradual tightening all around. I do want to note that the torque specs on that website are not accurate. Haynes 3MZ-FE manual shows 71 in-lbs for the both front and rear valve covers. Moreover, there was another gentleman who commented on a youtube video that he noted that the Toyota's 3MZ-FE shop manual showed 71 in-lbs also (however, I can only personally attest to the Haynes Manual which I own). In that DIY youtube video, the mechanic relied on the website you suggested and overtorqued the valve cover bolts to 9 ft-lbs (108 in-lbs), causing one of this bolts to break! So, I would highly suggest following more reputable sources like Toyota/Lexus service manuals and Chilton/Haynes Manuals.
Tail lights come on after vehicle is shut off
RX400h replied to bendutton17's topic in 01 - 06 Lexus LS430
S
- Last week
Report this to NHTSA as a safety and security issue. Lexus not sharing all the info, campaign is no longer listed on the app. I think they are trying to stuff the digital key down our throats, glitchy and unsafe as it is. Its all about profit.......
Shifter interlock 2023 NX350
Mike Black replied to tak06's topic in Lexus NX200 / NX300 / NX350 / NX450 / NXh+ Club
I have a 2024 NX350H and I haven't noticed undue pressure needed. It does have to be pressed a fair bit -- probably much more than what it takes for the brake lights. Have you done a distance measure of the brake pedal to see the difference between brake lights and shifting? I'll have to check mine. -
Mark Levinson sound system
filmlaw posted a topic in Lexus NX200 / NX300 / NX350 / NX450 / NXh+ Club
I am really interested in great car audio. Does anyone have any thoughts on how to set the treble, bass and midrange as well as how to balance the speakers to get the best sound from the driver's seat? -
What are the Possible Causes of the DTC P1127 Lexus? NOTE: The causes shown may not be a complete list of all potential problems, and it is possible that there may be other causes. Faulty Electronic Throttle Control System (ETCS) Actuator Electronic Throttle Control System (ETCS) Actuator harness is open or shorted Electronic Throttle Control System (ETCS) Actuator circuit poor electrical connection Read more: https://www.autocodes.com/p1127_lexus.html It may be that locating the specific cause is not exactly simple for the doityourselfer.
Report to NHTSA as a safety and security concern. Digital key is not the answer - just more revenue/profit for Lexus ar our expense.
Antenna Mast Replacement On 2004 Sc430
Woofwoof replied to jpwonderdog's topic in 01 - 10 Lexus SC430
Works like a charm is right. THANK YOU. -
Hi I am new to this group i own two Lexus 2014 RX350 and recently purchased 2021 NX350AWD and having problem with my 2021 NX350 rearview camera try to get the problem solve with Lexus in past 4 months and still have no clear answer from Lexus if they are going to fix it. Rearview camera is defected not functioning when put on reverse and screen is blank which is part of Lexus safety future when backup i don't know where to turn after four months try to get it fix but Lexus keep telling that camera part 67B0F6021 Camera Assy is in back order and every time i call they keep saying that still backorder but continue promising new ETA of the camera, if anyone can direct me to better way to get Lexus attention and looking to my issued i greatly appreciate the reply and input.
02 ES300 constant revving after starting
Seanamus replied to Seanamus's topic in 92 - 06 Lexus ES250/300/330
Thank you RX. I'll keep yiu posted. -
I found this information by running a Bing CoPilot search, given your information:
My Lexus rx300 is immaculate only done 47000,full service history ,showroom condition inside and out ,been unused for 15 years due too illness,car used once a week for local shopping it’s mint condition,still new too look at,2002 first registered,timing belt done by Lexus only about 1000 miles ago,because of cars age,brake pads are renewed,good for 150.000 miles,would swop for Bentley,you won’t buy a better car then mine,
GS350 F SPORT BRAKES
Creighton replied to IMMYUSEF's topic in 2013 - Present Lexus GS350 / GS350 F / GS540h
I have a 2014 gs350 fsport, rwd & am replacing all 4 pads & rotors & was looking for a recommendation. I've done tons of research on Amazon, eBay, forums, etc. im getting mildly overwhelmed w all the did things I've read. -
It looks like this sound was not present when you bought the vehicle? Is your RX still under warranty? If there is a Toyota-equivalent vehicle, then typically the service cost would be less expensive than at a Lexus dealership. I've had our spark plugs and coolant changed at our local Toyota dealership. Its reduction in cost for the maintenance tasks were significant.
I bought my SC400 about 4 days ago. When I bought it, it was starting good and running pretty well for a 1993. Only 150k Miles on her. In between that time the car alarm did go off when I was trying to unlock her, so it made me think about anti-theft. So When I try to start it the light cluster turns on, just no crank, No start. at first I thought it was the starter so I tested it by jumping the starter relay, but no when I have the key in on and jump the starter relay she starts right up and runs pretty well. She is kinda sluggish. Which is a whole other thing. Just need some opinions.
Rotten Egg Smell In Ls-460 And Break Noise
djambo replied to Mercury Chariot's topic in 07 - 16 Lexus LS460 / LS460L / LS600h
Hello all, even though that is an old topic ( sulfur smell inside the vehicle), I would like to know whether a solution has been found by any of you. I found the leak on both sides of the center console ( between the front seats), and Im sure of it because there are white residue prints on both side of the plastic side cover and the carpet under it smell the same. In my case, I dont drive above 2000rpm, and mostly is noticeable when I park the vehicle for some time and close the windows. What is strange is that no smell is present when you stat next to the vehicle, but once you open the door, it is hitting you in the nose directly. Thanks in advance! - Earlier
Thanks. I replaced the battery and the charge was covered by Lexus, although I have been unable to confirm if the battery was bad (long story). In the final analysis, either the battery was bad or the charging mechanism (alternator or otherwise) wasn't working. If the former is the case, then the problem has been solved (hopefully). If the latter, either that is a significant engineering defect or I need some direction on how to keep the 12 V charged. The question is whether the 12 v battery charges while the car is on EV mode. If the 12 V runs down after every few hundred miles, then that is not sustainable and if there is something in my driving habits (such as operating almost exclusively on EV mode) that needs to change, it would be useful to know. In the meantime, I am getting jumper cables. Until this happened, I had no idea that these were necessary for a PHEV.
Topics
