  1. Lexus Forum of North America
    1. General Chat
      Discuss anything about Lexus or any other topics (questions related to specific Lexus models please use the categories above)
      29.3k
      posts
    2. The Club Lounge
      Talk about other topics here not related to Lexus.
      20.2k
      posts
    3. 1.3k
      posts
  2. Lexus Owners Club - Lexus Forums
    1. 72.8k
      posts
    2. 80.7k
      posts
    3. 42.5k
      posts
    4. 42.6k
      posts
    5. 33k
      posts
    6. 8.9k
      posts
    7. 10k
      posts
    8. 112.8k
      posts
    9. Lexus RC Owners Club RC200t / RC350 / RC300h & RC-F Club
      The worlds first Lexus RC Owners Club
      225
      posts
    10. 343
      posts
    11. 159
      posts
    12. 151
      posts
    13. 182
      posts
    14. 16
      posts
    15. 33
      posts
    16. 250
      posts
    17. 125
      posts
    18. 4
      posts
  3. Lexus Marketplace
    1. Lexus Buy & Sell Area
      Forum to advertise Lexus parts or parts for your Lexus -either for sale, or wanted to buy.
      No commercial trading allowed. Trader should contact a staff member.
      2.1k
      posts
  4. General Lexus Forums
    1. 4.4k
      posts
    2. Lexus Modifications Forums
      Forum to discuss modifiying your Lexus. Discuss Lexus styling (body kits etc ), performance tuning (turbo chargers, superchargers, exhausts, intakes, filters, brakes) for all Lexus models
      1.7k
      posts
    3. Audio / Video / Electronics Forums
      Forum to discuss the ICE setup in your Lexus. DVD player? X-Box install? Play station? New sub? Share your Lexus in car entertainment here.
      5.1k
      posts
    4. Wheels and Tires Forums
      Forum to discuss wheels (Lexus and OEM rims), tyres of all makes and manufacturers. Alloy wheels, Chrome rims - you have a new set of wheels on your Lexus - this is the forum to show them off in.
      4.2k
      posts
    5. Lexus Detailing and Car Care Forum
      Forum to discuss making your Lexus look the business, waxes, polishes, techniques
      9.3k
      posts
    6. Lexus Warranty Discussions
      Discuss Lexus Warranty Issues.
      348
      posts
    7. Dealers & Pricing Forums
      Forum to discuss and share your experiences with Lexus dealerships
      1k
      posts
  • Member Statistics
    181,151
    Total Members
    2,069
    Most Online
    Boboso52
    Newest Member
    Boboso52
    Joined
  • Join The Club
    Join the Lexus Owners Club and be part of the Community. It's FREE!
  • Topics
  • Recent Achievements
    • Boboso52 earned a badge
      First Post
    • Aikimatt earned a badge
      First Post
    • Anner earned a badge
      First Post
    • gotflute earned a badge
      One Year In
    • sefner earned a badge
      One Month Later
  • Posts
    • Call your local dealer.  Most have a technology expert on staff.
    • I had similar ride issues with my 2015. I had an alignment done by a reputable shop. No more issues. I do not have any cabin noise so not sure what that is about.
    • It seems I am having a similar issue, I just ordered some new NGK coils, wires and spark plugs along with OEM Denso fuel injectors, we have the same year make and model, mines idles high when warming up but after the warm up it is normal, however the misfires feel more like a stutter than anything, they don't feel that bad however it is noticeable and bothers me alot, I have CEL for P0300, P0301, P0303 and P0305, so misfires in cylinders 1,3 and 5. I hope everything I order will help me fix this issue if not then we will see, but I digress, if there are any people here who can give me any advice on why my car is still suttering that would be great thank you!
    • I'm thinking I'll add a fuse tap to the existing fuse.   Important: After watching a long youtube video (below) if the solar pannel doesn't get enough sun then the charge controller will slowly drain the battery. Important: Fuse tap allows this all to be fused. However, fuse tap orientation matters, if it's hooked up backwards then both fuses are in series, not parallel.  Connector types: - Fuse Tap - SAE 2-pin connector (also called SAE Connector Bullet or SAE Quick disconnect) Thought: A normally open relay could stop the parasitic draw. These are also sometimes called Voltage Sensitive Relays Could add a VSR Voltage Sensitive Relay to disconnect solar charge controller when there is no power coming from the solar panel. This might help with parasitic draw. This might be a bad idea because the relay could take a fair amount of the solar power to close... https://diysolarforum.com/threads/relay-to-shut-off-solar-panel.15331/   Maybe a latching relay would work:  https://diysolarforum.com/threads/relays-nc-vs-no-or-other-solution.2267/    Seems like Harbor Freight has Thunderbolt Solar products that will help/make this easy: - Simple solar charge controller: THUNDERBOLT SOLAR 100 Watt Solar Charge Regulator SKU(s) 96728, 94048 $20 https://www.harborfreight.com/7-amp-solar-charge-regulator-96728.html - Kit to help with wiring: $14 THUNDERBOLT SOLAR Solar Power Connection Cable Kit SKU 59171 https://www.harborfreight.com/solar-power-connection-cable-kit-59171.html - Small solar panel, could get 2: $15 THUNDERBOLT SOLAR 1.5 Watt Solar Battery Maintainer SKU(s) 64251, 44768, 68692, 62449 https://www.harborfreight.com/15-watt-solar-battery-maintainer-64251.html - Hub if I want multiple panels $18: THUNDERBOLT SOLAR 400 Watt Universal Solar Connector SKU 68689 https://www.harborfreight.com/400-watt-universal-solar-connector-68689.html   Key thoughts and notes: 1. Need to make sure there is enough sun otherwise it's all a waste and will drain the battery FASTER 2. Use a charge controller 3. Use a fuse tap   To prep, I'd need to find: - Best fuse spot to use - A good spot to connect a ground wire near the fuse block   So wiring would go like this: Inside the car Fuse Panel -> Always on fuse (find with multimeter) Insert fuse tap to split power 10amp fuse for this part of the tap (original fuse for original fused connection) Cut the solar extension kit's SAE 2-pin extension cable and wire positive to the fuse tap and negative to the car ground so one end goes to fuse tap the other end has an SAE 2-pin adapter on it Possibly: Put a normally open 12V relay or Voltage Sensitive Relay in line to disconnect charge controller unless panel gets power. This would then be wired to the universal hub   Connect SAE 2-pin to the charge controller's battery side Connect the SAE 2-pin charge controller's solar side to the solar panel universal connector hub (skip this if only using 1 panel and no relay/VSR from step 5 Connect solar panel to universal hub Important: Technically, if you're using more than 1 solar panel you should install a 1-way diode between the solar panel and the hub. This would stop backflow of power into the other solar panels which could cause a fire if one is faulty and the other(s) are cranking out a lot of power Do this at your own risk, these are just my ideas.   Fuse tap: Buy local     Some other links and thinking:  https://www.zhpmafia.com/forums/showthread.php?23079-Using-Solar-Charger-for-Battery-Maintain-Parasitic-Drain  https://www.skoolie.net/forums/f28/battery-self-draining-because-of-charge-controller-15776.html   Charge controllers draining the battery: https://diysolarforum.com/threads/should-i-worry-about-a-draw-on-my-battery-from-charge-controller-overnight.50004/ Video about charge controllers draining battery if not enough sun
    • Welp, I knew I should have cleaned the driver's side while cleaning the passenger side....  Driver's side flooded last weekend.  However, now it was quick work with the experience of the passenger side. Doing it a second time around here are some pro tips: - Canned air from the top of the rail is a good start - Coat hanger is the way to go for the bottom - Rubbing alcohol (isopropyl) can really kill any funk in the car.   Driver's side tip: The accelerator Stopper Rod looks like it needs to unscrew, but you just pull the mat around it and it comes up. The carpet is just tucked in underneath.   The driver's side carpet was soaked. I pulled it all up, put a fan underneath and it dried in ~20 hours (of being in the sun with fans on and windows cracked. Then I soaked the carpet and floormats in isopropyl, and completely doused them. I used at least a quart just for the driver's side and then used another 2 quarts for the passenger and rear carpets just to try to freshen up the car. Left for another 24 hours. No smell! This is gold & I'll use this trick again if I need to!
