My center console will not open. The latch seems not to be pulling the actual latch itself open. Any tricks short of removing console? Help appreciated.
Have you put anythng in there which may have jammed the latch? Not the ideal solution but press the button and give it a good pull upwards or try inserting a flat blade.
Try to push console cover from end seat side to front pressing console open button in the same time - should open.
  • 3 months later...
Same issue with mine, I have to press forward on the lid whie pressing the open button. The lid seems "loose" causing the alignment to be off. Fix?
I just fixed this on my console. Symptom was if I slide the top cover forward as I closed and opened it, it worked fine.
I disassembled and found the screws from the hinge (58907-50030) to the top cover had worked loose. Just had to tighten those up and I was good to go. Its a bit of work to get the cover out. Basically you are removing the inner console box and cover as a unit.
post-88814-0-89308100-1357743022_thumb.j
  • 8 years later...
Hi and thanks for this info. We have the same problem and opening the console trick was as most people found is to slide the lid forward.
You mention it was a bit tricky getting the inner box out, any clues? I am an old b.... with arthritic fingers so have to think about what I tackle, too many years working with my hands!
This is our third LS430 and should NEVER have gone away experimenting with Jeep and Volvo.
