Ok so today I turned on my hazards because I had to empty things out of my trunk and I noticed that the right rear blinker wasn't come on at all so then I turned off my hazzards then to turned on my right blinker and nothing so then I went and got some new bulbs because I was sure that, that was gonna fix it but still nothing brand new bulbs did nothing and I checked with a volt meter to see if I was getting power and everything seemed good. Please help.
Hi Kevin.
If you are getting power to the bulb and the bulb works okay then I would check the earth connection for the tail light unit as that is all it can be.
Let us know how you get on with it
Cheers  Trevor
As Trevor stated above, I agree also check the bulb and see if possibly it got went? maybe the tail lights are not  in all the way? But check the connections! Let us know
MI need did the same thing. Check power....good. along side of the bulb socket  Is the ground wire. I pushed that wire up and bent over the side of the socket. And the bulb started working.
yeah I ended up just buying a new socket piece and connected it and it worked instantly and it was pretty cheap and easy to do
