HELP!!
I still have my 2000 RX300, original owner with 160,000 miles, runs flawlessly, I love it.
The small light in the upper corner of the headlamp assembly has gone out. I have changed the bulbs in the other lamps but can't figure out how to get to the small lamp in the corner. (see picture, I've circled it in red)
I hope that I can just replace the bulb rather than the entire headlight assembly.
Has anyone replaced this bulb or does anyone have any suggestions?
Thanks all.
Love My Lexus!
  • 4 weeks later...
You'll have to remove (pull away) the wheel well liner, then reach up to gain access to the rear of the bulb.
  • 9 months later...
I know this is an old thread, but does anyone know the name of the lamp? And/or what is the replacement bulb size?
Thanks!
Hi jc4home 2 and welcome.
I would start with a call to your local Lexus dealers parts department. There is no reason for them not to help you as your only asking for the cost of the part and its technical info such as part number and cost.
If you don't want to call the parts department you can try Auto Zone or an independent mechanics shop. You may also check with the local Toyota dealer.
Paul
No its a parking lamp as noted above....
