emesen Posted February 4, 2014 Posted February 4, 2014 Hi, I recently bought RX350 2007. I have found that the rubber pipes coming out from the Engine air filter are bit messed up. Every small rubber pipe that is connected to the airfilter must be connected to some part in the engine. But in my RX350 2 of the small pipes are not connected any where. Can any body post some detailed picutures of the engine bay showing where the pipes from airfilter are coming from the going to. Thanks
LEXIRX330 Posted February 4, 2014 Posted February 4, 2014 Welcome to LOC! Not sure if I will be able to help with this one. Did you try searching for images of a engine diagram? Hopefully someone will chime in.
jamesm182 Posted February 4, 2014 Posted February 4, 2014 Hi and welcome to LOC! Maybe post some images up of your own car and someone may be able to help? :)
RX400h Posted February 5, 2014 Posted February 5, 2014 Okay, I have to ask: Did you look at the engine before you bought your RX?
jetfixer01 Posted February 8, 2014 Posted February 8, 2014 Sounds like the two small vacuum hoses that should go to the vacuum tank located on the underside of the air cleaner housing assembly.
