bstoneice91 Posted March 31, 2003 Share Posted March 31, 2003 I have a 96 SC400, recently the rear speakers went out. The Sub woofer is still operational, however I have no sound to the rear speakers. Any Ideas? or similar experiences? Thanks, Bob. Quote Link to comment Share on other sites More sharing options...
rich21 Posted November 30, 2003 Share Posted November 30, 2003 i have the same problem. help!!! Quote Link to comment Share on other sites More sharing options...
AWJ Posted November 30, 2003 Share Posted November 30, 2003 Speaker is probably bad. Test with known good speaker. Match the impedance on a replacement. Quote Link to comment Share on other sites More sharing options...
Mr. O Posted January 16, 2004 Share Posted January 16, 2004 i have the same problem and ive checked the speakers and there fine. I think its the amp. That what someone at a car audio place told me. Its a matter of just getting a new amp now. But i have no idea which amp to get. any ideas? Quote Link to comment Share on other sites More sharing options...
nvach001 Posted May 24, 2004 Share Posted May 24, 2004 i have the same problem and ive checked the speakers and there fine. I think its the amp. That what someone at a car audio place told me. Its a matter of just getting a new amp now. But i have no idea which amp to get. any ideas? I have recently purchased a 1995 sc400 and I have noticed that the rear speakers are out as well. If anyone has solved their rear speaker problem, I would love to know what it was and how you fixed it. Thanks a lot!! Quote Link to comment Share on other sites More sharing options...
gcarpent Posted December 3, 2004 Share Posted December 3, 2004 Disconnect the wiring harness from the amp, check continuity between the Red wire and the White wire, and between Black wire and the yellow wire "NOTE THIS IS THE HARNESS THAT COMES FROM THE HEAD UNIT, NOTE THE ONE THAT GOES TO THE SPEAKERS". If you do not have continuity between these terminals, remove the head unit and check continuity on the wiring harness from the head unit end to the amp end. Chances are it is just like my system was when I had this problem and the head unit was bad. Quote Link to comment Share on other sites More sharing options...
dcfish Posted December 3, 2004 Share Posted December 3, 2004 Disconnect the wiring harness from the amp, check continuity between the Red wire and the White wire, and between Black wire and the yellow wire "NOTE THIS IS THE HARNESS THAT COMES FROM THE HEAD UNIT, NOTE THE ONE THAT GOES TO THE SPEAKERS". If you do not have continuity between these terminals, remove the head unit and check continuity on the wiring harness from the head unit end to the amp end. Chances are it is just like my system was when I had this problem and the head unit was bad. ← It is your amp... They tend to fail because of there position in the trunk , They get wet [ carwash , rain etc...] and the trunk seal , antena seal , and the drain hose that usually gets crimped or cloged. Check everything mentioned and if you need a amp email or pm me . ;) Quote Link to comment Share on other sites More sharing options...
Ron M. Posted November 20, 2005 Share Posted November 20, 2005 I'm having rear speaker problems in my 95 SC400 as well. Have taken out the amp and ran the continuity checks you suggested. They are as follows. Between the Red and White I show continuity and read about 3.8 ohms. Between Black and Yellow, no continuity, or infinite ohms. Not sure though exactly what this proves though, because I have no schematic to go by. Any help? Thanks Ron M. Quote Link to comment Share on other sites More sharing options...
JtathBSC400 Posted November 26, 2005 Share Posted November 26, 2005 Read this....... http://www.carstereohelp.com/repairDoItYou...usRepairVol.htm It shows one of the most common problems and how to locate and fix it. Try the small things before you spend the big bucks. Just because the speakers aren’t working doesn’t necessarily mean that the amp is bad, check the connections first. And if the car has the car phone, disconnect it and see if that solves your problem. Quote Link to comment Share on other sites More sharing options...
