Passanger Window Rear Will Not Roll Down
INSOCAL909
Have a 1993 GS30 that the rear passanger window will not operate. It will operate from driver door. Have replaced the switch and tested the new switch on other doors. Any suggestion....
Hi Insocal and welcome to the LOC.
The best guess is the actuator in the lower part of the door that runs the glass up and down. You'll have to take off the interior door panel to get to it. If this is not it then the motor is the next place to look. By the way, when you replaced the switch in the door, did you check for voltage present?
Paul
