compumedic Posted January 29, 2012 Share Posted January 29, 2012 I just recently had my alternator replace. during the install the mechanic helper in jump starting the vehicle using a booster box connected the negative to the positive and vice versa. since then, to start the vehicle you must jump it to do so. the battery has been replaced and the alternator shows it is charging correctly. the vehicle starts with a jump on the first attempt. so it seems that the auto now needs additional amps to start. has anyone encountered a similar issue with starting? is this a starter or a fuse issue? any assistance in the right direction would be appreciated. Quote Link to comment Share on other sites More sharing options...
billydpowell Posted January 29, 2012 Share Posted January 29, 2012 see my new post on Club Lexus, hope it works for you. Quote Link to comment Share on other sites More sharing options...
landar Posted January 30, 2012 Share Posted January 30, 2012 I am not sure what a booster box is and why positive to neg and vice versa. When you jump or boost a battery, it is positive to positive, negative to negative. Otherwise, 'spritzen sparken' results. Its a parallel (not series) connection. If the car starts with jumper cables and the battery is good... then, most likely, the battery clamp connection(s) are simply dirty. Remove those, clean and reassemble. Quote Link to comment Share on other sites More sharing options...
