thatlexusboy Posted May 1, 2008 Share Posted May 1, 2008 my friend has an 01 LS430 just like mine he has a problem with the steering, it will go up but slowly and down normally, in and out it wont go at all? whats the problem? what do i need? THANKS! Quote Link to comment Share on other sites More sharing options...
thatlexusboy Posted May 1, 2008 Author Share Posted May 1, 2008 do i need a new motor for it? Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted May 1, 2008 Share Posted May 1, 2008 common problem I think.. I've heard of a lot of older LSs auto tilt/telescope feature going out, i think it's the motor. Let's just hope it dies in your favorite position :) heheh Quote Link to comment Share on other sites More sharing options...
Blake_batonrouge Posted May 1, 2008 Share Posted May 1, 2008 common problem I think.. I've heard of a lot of older LSs auto tilt/telescope feature going out, i think it's the motor. Let's just hope it dies in your favorite position :) heheh I agree with you!!!! Mine died in the "key out" position. NO matter how i sit, my arms are still up in the air. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted May 1, 2008 Share Posted May 1, 2008 That's one reason for not using the "auto" feature. As convenient (decadent imo) as it is for the big fellas that need it, I'd hate to have to drive the car with it parked in the up & in position. Quote Link to comment Share on other sites More sharing options...
thatlexusboy Posted May 1, 2008 Author Share Posted May 1, 2008 common problem I think.. I've heard of a lot of older LSs auto tilt/telescope feature going out, i think it's the motor. Let's just hope it dies in your favorite position :) heheh lmao Quote Link to comment Share on other sites More sharing options...
thatlexusboy Posted May 2, 2008 Author Share Posted May 2, 2008 anyone know where i can buy the motor? Quote Link to comment Share on other sites More sharing options...
RFeldes Posted May 2, 2008 Share Posted May 2, 2008 Let us know if you hear the motor and no movement. Quote Link to comment Share on other sites More sharing options...
Blake_batonrouge Posted May 2, 2008 Share Posted May 2, 2008 Finally was able to fix something!!! Yesterday afternoon, I went outside and fixed the steering wheel. It took me about 10mins at the most. My gear is kinda warped and the teeth were not making contact. I loosened the wheel and placed a washer behind it. All is well now :D Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted May 2, 2008 Share Posted May 2, 2008 Finally was able to fix something!!! Yesterday afternoon, I went outside and fixed the steering wheel. It took me about 10mins at the most. My gear is kinda warped and the teeth were not making contact. I loosened the wheel and placed a washer behind it. All is well now :D Thanks for posting your fix. Quote Link to comment Share on other sites More sharing options...
Blake_batonrouge Posted May 2, 2008 Share Posted May 2, 2008 Thanks for posting your fix. I tried to link it but i can't figure out how. I got the washers at home depot for $1 Quote Link to comment Share on other sites More sharing options...
RFeldes Posted May 3, 2008 Share Posted May 3, 2008 That fix is well noted here if you search..that is why I asked if you hear the motor running. There are pix and the fix if you search. Please use the search feature. :o Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted May 3, 2008 Share Posted May 3, 2008 New to me but then I haven't had that problem to warrant a search. Should have known this wasn't the first thread posted. Any time I've searched anything I have always found an abundance of information and more than a few solutions to just about any topic. A virtual cornucopia of technical solutions. With some politics, humor and economics thrown in for good measure. B) Quote Link to comment Share on other sites More sharing options...
devious623 Posted June 23, 2008 Share Posted June 23, 2008 Finally was able to fix something!!! Yesterday afternoon, I went outside and fixed the steering wheel. It took me about 10mins at the most. My gear is kinda warped and the teeth were not making contact. I loosened the wheel and placed a washer behind it. All is well now :D i would like to know how and what size washers to put on the wheel,mines went out on me when replacing p/s pump and re-connecting my altenator/battery!it wouldn't come down when inserting the key in the ignition,need help,i feel like i'm driving a school bus!!!!!!!!! HELP ME SOMEONE????? :( Quote Link to comment Share on other sites More sharing options...
cjmeyer Posted June 23, 2008 Share Posted June 23, 2008 Finally was able to fix something!!! Yesterday afternoon, I went outside and fixed the steering wheel. It took me about 10mins at the most. My gear is kinda warped and the teeth were not making contact. I loosened the wheel and placed a washer behind it. All is well now :D i would like to know how and what size washers to put on the wheel,mines went out on me when replacing p/s pump and re-connecting my altenator/battery!it wouldn't come down when inserting the key in the ignition,need help,i feel like i'm driving a school bus!!!!!!!!! HELP ME SOMEONE????? :( I recently had to add 2 washers to mine.I purchased 2 rubber hose washers from Ace hardware for 42cents.Spent about 15 minutes taking it apart and puting back together and was back in business.The gear eventually gets pushed past the drive and loses contact.The washers bring it out so the gear meshes again.Make sure you use some lube on the gear when you put back together.I am no mechanic as I have stated before but anyone can do this job.Dealer won't repair but will replace the whole assembly for about $800 Quote Link to comment Share on other sites More sharing options...
