bluethunder2008 Posted January 15, 2008 Share Posted January 15, 2008 Hi, I have LS98 (Halogen , the white blue color light), and it works fine with me, those days I started to get this issue, the left headlamp turns off after 2-5 minutes while I'm driving. Does that mean I need to change the lamp only ? or there is something wrong in the wiring ? I need your suggestion. Quote Link to comment Share on other sites More sharing options...
RFeldes Posted January 15, 2008 Share Posted January 15, 2008 Sounds like the heat from the lamp is causing contact separation. Pull the lamp and clean its contact and the plug contact with a contact cleaner or eraser and try again. Quote Link to comment Share on other sites More sharing options...
qha_vn Posted January 16, 2008 Share Posted January 16, 2008 i got this same problem which was the bad headlight plug. the plug gets hot after a while and cause contact problem. cleaning it wont solve the issue long, you may need to replace the plug. I did replace it few months ago and the issue never comes back Quote Link to comment Share on other sites More sharing options...
SKperformance Posted January 16, 2008 Share Posted January 16, 2008 swap bulbs left and right and see what happens Quote Link to comment Share on other sites More sharing options...
bluethunder2008 Posted January 24, 2008 Author Share Posted January 24, 2008 I found the cause of this problem... The lamp switch in the steering does not work correctly, yesterday I pressed it little hard and the lamps stayed on the hole trip, then today I tried to play with it, it seems like a lose inside it. like the sound tick tick.. I think I need to find a replacement for it... Hi, I have LS98 (Halogen , the white blue color light), and it works fine with me, those days I started to get this issue, the left headlamp turns off after 2-5 minutes while I'm driving. Does that mean I need to change the lamp only ? or there is something wrong in the wiring ? I need your suggestion. Quote Link to comment Share on other sites More sharing options...
