My 1990 LS400 is in great shape, but the gray leather seats, front and back, are starting to show some cracking. Is there a product that will "fill" the fine white cracks with a gray color to hide them?
I swear by the Lexol product line. I bought mine at Pep Boys. There is a cleaner and a conditioner. I use it about every 6 months and the leather in both of the Lexus' looks brand new!
Lexol has great products but it want fix craked leather.
ROBERT,
Yea that's what I'm looking for, "filling/hiding" the cracks. If the white in the cracks could be colored somehow it would help hide the cracks I am hoping.
You can't restore CRACKED leather, you can make it look a little better with these leather products but that's it... Ebay for leather new covers is what I did, then went to an uphostery shop and had them installed...$600 for the new leather covers and $300 to install.. New interior....Vallla...
If the cracks are not through the leather you can try dye. It can darken the lighter cracked areas. It may be difficult to find a perfect match though. If the cracks go through the cover, I'd say you'll have to buy new covers.
Dye will work for a while but eventually fade and fade onto your clothes... I've tried the dye method before and it a temporary solution...
Thanks for the reply. The cracks don't go all the way through, they are just on the surface. What kind of dye would I use?
There is a product called Marhide that should work well.
This is the stuff/procedure that I would recommend. It is a filler and a dye. Cracked leather will not dye uniformly, you need to fill in the cracks with an elastic filler and then dye area or entire panel for a uniform look. I saw another product on Ebay that was US sourced and was specific to the Lexus LS400 gray interior that I have, but I cant find it anymore. Same type of stuff, a filler and a dye, sealer. Ebay item 140166319788
Thanks for the idea, I am going to try it.
Thanks again everyone for the help.
How about a few pics before and after and a review of the product. Ill do it if it works.
You got it, I will post before and after pictures.
Except for replacing the leather, you may be chasing your tail on this one. I have a similar problem from when I bought my 91 recently. The previous owner who purchased the car new had never conditioned the seats. The seats were hard, more like a 91 Mercedes than a 91 Lexus. Once I started conditioning them, the cracks started showing up. I think the only good remedy if you plan on keeping the car is to replace the leather... I found this company online. I think the total cost of materials is around $750 or so. They recommend professional install but you may be able to do it yourself.
Katzkin Leather Upholstery's
Jim
