Removing Rear Rotors On 2000 Gs300
There is actually quite a bit more to this than just removing the caliper and hitting it with a hammer. You have to turn the gear that loosens the parking brake, then the rotors will come off easily.
you don't have to do that but if you choose to loosen your e-brake then make sure you re tighten them otherwise you may have a really loose e-brake when you need it
