FLNH Posted June 11, 2007 Posted June 11, 2007 I do not live anywhere near a dealer and wanted my 2007 LS460 oil change locally. Mechanic said he could not get oil filter. After searching the internet, neither could I. Any suggestions?
dcfish Posted June 11, 2007 Posted June 11, 2007 Call your local dealer and have them ship one. I needed a tranny drain plug and my lexus dealer sent it out speedy delivery at no cost for delivery. Now that is service.
SW03ES Posted June 11, 2007 Posted June 11, 2007 You can also order the oil filters online from one of the many Lexus parts outlets, try www.lexus-parts.com. The Lexus filter is one of the better filters anyways. You should be using it regardless of who changes your oil.
FLNH Posted June 13, 2007 Author Posted June 13, 2007 They may not have the filter. I searched the internet including Lexus-parts.com and everything seems available except this particular oil filter. I am going to go to the dealer and just make a day of it.
SW03ES Posted June 14, 2007 Posted June 14, 2007 It may be a different filter not everybody has in stock yet. Call Lexus-Parts.com, its run by Sewell Lexus in TX, they service LS460s they must have the flters they may not be on the site yet.
FLG8R Posted July 20, 2007 Posted July 20, 2007 Is the new LS still using a can type filter? You replace the internal "sponge" part of the filter. The actual housing is reused.
Robert Young Posted August 6, 2007 Posted August 6, 2007 Toyota in general must be going to this "new" design (really it is an older design, similar to what I've had on old Alfa Romeos). This new for Toyota design is also on the new Tundra pickup (at least on the new 5.7L engine).
DArustik Posted August 6, 2007 Posted August 6, 2007 Toyota in general must be going to this "new" design (really it is an older design, similar to what I've had on old Alfa Romeos). This new for Toyota design is also on the new Tundra pickup (at least on the new 5.7L engine). I hate trucks like the Tundra, unless you are in construction etc.
Craig B Posted August 6, 2007 Posted August 6, 2007 Any Toyota dealer can order the filter for you. Here is the part # 0415238010. You can also order one from http://www.irontoad.com Remember the car takes 9.1 quarts of 0W20 oil that can also be purchased at your Toyota dealership. You can also purchase Mobil 1 the same oil used by Toyota from an auto parts store for around $6 per quart. Craig
CAPls460 Posted September 22, 2007 Posted September 22, 2007 Any Toyota dealer can order the filter for you. Here is the part # 0415238010. You can also order one fromhttp://www.irontoad.com Remember the car takes 9.1 quarts of 0W20 oil that can also be purchased at your Toyota dealership. You can also purchase Mobil 1 the same oil used by Toyota from an auto parts store for around $6 per quart. Craig I paid $9.49 for the filter at a Lexus dealer and plan to use Quaker State 5-20W at my 8,000 mile oil change. Had the free 5,000 mile oil & filter change at the dealer and they did a sloppy job. I plan to change the oil every 3K going forward.
FTE Posted October 5, 2007 Posted October 5, 2007 I finally ordered mine from my dealer (15 a pop) in NM. We live in WY. It's an odd filter but an experienced jiffy lube can do it if they have changed Toyotas. I suspect it's the same one as used in the Toyo V8 and much cheaper.
Re_ Posted October 14, 2007 Posted October 14, 2007 I finally ordered mine from my dealer (15 a pop) in NM. We live in WY. It's an odd filter but an experienced jiffy lube can do it if they have changed Toyotas. I suspect it's the same one as used in the Toyo V8 and much cheaper. Subscribing
mehullica Posted October 15, 2007 Posted October 15, 2007 All LS460's come filled from the factory with full synthetic oil.
FTE Posted October 19, 2007 Posted October 19, 2007 All LS460's come filled from the factory with full synthetic oil. I asked my salesman in Albuquerque what the 460 shipped with. He said it was a syn blend and he didn't know the weight. I'm using Mobil 1 5-20 but would prefer 0-20 esp in the cold of WY. I should have talked to the service manager...
