COZ Posted December 3, 2005 Share Posted December 3, 2005 An electronic burning smell coming from vents, heater is turned on. I saw this mentioned im another post and I noticed it last night for the first time. Like dust burning off an electric heating element. Anyone else notice this? Does Lexus use an electric heating element to heat the air? Quote Link to comment Share on other sites More sharing options...
LexKid630 Posted December 3, 2005 Share Posted December 3, 2005 An electronic burning smell coming from vents, heater is turned on. I saw this mentioned im another post and I noticed it last night for the first time. Like dust burning off an electric heating element. Anyone else notice this? Does Lexus use an electric heating element to heat the air? ← That was my post, and it is noticable. Not too much of a big deal, kind of goes away after a few minutes (or maybe i just get too used to it?). Just started happening last month when i first turned it on since last winter. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted December 3, 2005 Share Posted December 3, 2005 If it smells like oil it usually is the rear valve cover leaking on the manifold . Quote Link to comment Share on other sites More sharing options...
LexKid630 Posted December 3, 2005 Share Posted December 3, 2005 It smells kind of like a wood fire. At first i thought someone had a fire going outside but who's doing that on the highway?? LOL Quote Link to comment Share on other sites More sharing options...
lenore Posted December 3, 2005 Share Posted December 3, 2005 Is it possible that some leaves crumbled and worked their way down to the heater core, and maybe some debris is hitting the blower fan causing it to slow down, and overheating. I pay very close attention to leaves sitting on the air vents on the outside of the vehicle. I have replaced a few heater cores, and they can get contaminated with debris. I have no easy solution to fixing however. Quote Link to comment Share on other sites More sharing options...
LexKid630 Posted December 3, 2005 Share Posted December 3, 2005 Is it possible that some leaves crumbled and worked their way down to the heater core, and maybe some debris is hitting the blower fan causing it to slow down, and overheating. I pay very close attention to leaves sitting on the air vents on the outside of the vehicle. I have replaced a few heater cores, and they can get contaminated with debris. I have no easy solution to fixing however. ← Could be, i have never thought to look in the front grill for leaves Quote Link to comment Share on other sites More sharing options...
RX in NC Posted December 3, 2005 Share Posted December 3, 2005 I think that lenore nailed this one for you. Every weekend when I pop the hoods on all of our vehicles for their weekly fluid levels and tire pressure check-up, I take the time to remove any leaves or pine needles that may have accumulated up near the base of the windshield. It takes about 30 seconds per vehicle to do this. Add it to your weekly routine and you may find that the burning smell associated with cranking up your heater suddenly disappears. Keep in mind that accumulated debris in an engine compartment is never a good thing to allow. It can gradually interfere with performance depending on where the debris eventually settles, and it will certainly increase your chances for a fire under the hood. Quote Link to comment Share on other sites More sharing options...
LexKid630 Posted December 3, 2005 Share Posted December 3, 2005 I think that lenore nailed this one for you.Every weekend when I pop the hoods on all of our vehicles for their weekly fluid levels and tire pressure check-up, I take the time to remove any leaves or pine needles that may have accumulated up near the base of the windshield. It takes about 30 seconds per vehicle to do this. Add it to your weekly routine and you may find that the burning smell associated with cranking up your heater suddenly disappears. Keep in mind that accumulated debris in an engine compartment is never a good thing to allow. It can gradually interfere with performance depending on where the debris eventually settles, and it will certainly increase your chances for a fire under the hood. ← I went out to my garage to take a look at the rx330's engine compartment and it's gone...My wife took that today instead of her LS :( Oh well i'll just wait till she gets back. I agree that's probably what it is...i never thought of cleaning leaves off. Thanks i'll check it later! Quote Link to comment Share on other sites More sharing options...
lenore Posted December 3, 2005 Share Posted December 3, 2005 By the way the grill faacia under the hood or along the windshield may be removeable and possible you can clean by vacuuming underneath this piece. Quote Link to comment Share on other sites More sharing options...
COZ Posted December 3, 2005 Author Share Posted December 3, 2005 Thanks for the replys. I found pine needles in mine. We'll see if that clears it up. Quote Link to comment Share on other sites More sharing options...
