Clearing My Headlights In My 95 Es
bbsal
hi everyone well after reading all the posts about clearing the fron headlight i decided to do it.i toke them out put them in the oven and pryed away until they opened up.I have to say it really aint hard to do.once you take the headlight off the car just disconnect the bulds 1 screw amd put it in the oven on 350 for like 3 minutes or until nice and hot then just pry it open and pull the rest and it comes right open.i also really wanted to do this because my projectors were foggy so when i opened it i cleaned them and they look brand new again.i also used plastic compound and buffed the front cover and they now look perfect.i must say without that orange lens the headlights look 100 percent better.i give some pics of it too.
heres some more pictures when it was apart.also if you plan on doing this make sure you put it back in the oven and heat it back up so the silocon spreads back into place.i also put some fresh silicon around it so its air tight like new..
not that i am trying to correct ,just inform
they actually use urethane for the sealing of them as silicone is an easy bond to break
that is why you have to heat it back up
the silicone should still stay and hold to the ureathane they just have different expansion rates but as long as it it not extreme climate you should be ok
your right its urethane.i put black high temp silicon on them when i put it back together.im having a monster storm right now with heavy rain and they help up perfect all day so thats good news.
im about to do my back tail lights and i will give the hair dryer and also a heat gun that i have a shot and i will let yous know whats the best to use.i will try a couple different things just to see whats better.i would think the oven is still the best though.
i am not trying to sound negative
but a heat gun is only going to get one area hot enough for the ureathane to release
then when you move it around to the other areas it will cool
the problem is the whole assembly needs to be heated evenly of the outer plastic will crack from pressure
as some of the ureathane is letting go and other parts it is rock hard
just a thought
but anything is possible
just be careful
yep i was thinking the same thing.the oven is for sure the best way since it heats every part up.but im just going to try very carefully just to see if something else would work.if i see it doesnt im going to stop so i dont screw my light up.
i didnt but i gues to be safe you could.i just removed them little rubber hoses and the lights of course but thats about it.also you have to remove the metal clips all around the light.not hard to do at all.
probably beatin a dead horse, as they say, but i just now saw this post and thought i'd share what i know. i recently cleared the taillights on my ES, but i used a heatgun mostly to do it, and it all worked out pretty good. at first i put them in the oven, but after a few minutes, i noticed the black plastic "fin" on the top of the light that makes it flush with metal of the car around the trunk started to droop and melt, so i took it out. then i used a heatgun to remove the lens the rest of the way. on the second one, though, i used only the heatgun, and it actually went better than the first. the trick is to know where to apply the heat and force in order to avoid chipping a little piece off the outside with screwdrivers, like i did on one. i didnt heat them up when i reassemled them. prob. should've, but didn't have an oven at the time, but i put silicone around the outside and they haven't leaked yet! the key is definitely to take your time and be careful, and you should be fine. sorry this is so long, but i figured anyone who cared would appreciate hearin it all in one big heap rather than havin to wait! :D
well if the heat gun worked for you then that would be good for people without a oven but if you didnt reheat the light before putting it back together you cant be sure it will leak eventully.probably not at first because you have silicon on there but it will start to leak.silicon WONT hold the light together for very long.thats why theres urethane on them to hold it together.i still advice anyone who wants to clear there lights to MAKE SURE you put it back in the oven and reheat it before putting it together.
yeah, probably right about the eventual leaking. i wanted to reheat it, but the urethane was still pretty soft, so i put them together as best i could ( i actually literally stood on them, with towels on both sides) before i applied the silicone. im pretty sure there's no chance of them leakin soon, b/c they went back together almost as snug as they were factory before i ever put a drop of silicone on them. anyhow, i do agree that it certainly cant hurt anything. just had to make due with what i had at the time, ya know? B)
nice to kow the gun worked
i also used the ove to soften up the urethane and then perssed it back together
and only use the sealer on the outside edges after
as the urethane would selal together agian
the little fin on the rear lights
are you talking abuot where the lights for the liscense plate are that melted?
you were supposed to remove them as they are seperate assemblies and it just screws on to the light for support
i forgot on one of mine and it also melted nicely
but the rest of the light was perfect
no, i removed those, but sucks that you didn't! sorry about that man. no, if you look at the taillights when they're on your car, there's this black part that makes the light flush with the trunk. this is actually part of the light assembly, and that's what i was talkin about. anyhow, its no big deal; i caught it b4 it got bad and bent it back, so its all good. but yeah, if you use it right, the heat gun works great! i dunno why no one else ever thought of that. guess not everyone has one!
