jschunke Posted December 8, 2004 Share Posted December 8, 2004 My dad's battery in his '93 LS400 goes dead after the car sits for a week or so and then it won't start. It has a 3 year old DieHard. Does the LS typically draw a substantial current when the ignition is off? Is there a specification on a typical current draw? Thanks. Quote Link to comment Share on other sites More sharing options...
bartkat Posted December 8, 2004 Share Posted December 8, 2004 Perhaps he doesn't drive enough to keep it fully charged. Have you tried giving it a full slow charge? Quote Link to comment Share on other sites More sharing options...
silvermate Posted December 8, 2004 Share Posted December 8, 2004 if its a 3 year old battery, its just time for it to be replaced there could be another problem thats drawing charge out ie......glove box light on, an interior light that stays on, or if an aftermarket Cd player is installed, it could be hooked up wrong, and the Cd player is still drawing power even when the car is off. Quote Link to comment Share on other sites More sharing options...
SW03ES Posted December 8, 2004 Share Posted December 8, 2004 Yeah I agree, if its 3 years old it just needs to be replaced. Batteries can only hope to last ~ 5 years, and having the car sit a long time without driving it shortens the battery life. I always replace batteries as a maintenance item every 3 years. Quote Link to comment Share on other sites More sharing options...
flanker271 Posted December 9, 2004 Share Posted December 9, 2004 Does the LS typicallydraw a substantial current when the ignition is off? No it doesn't. In fact any car shouldn't do this. These are NiCd batteries. After years of use they'll develope a memory effect, which prevents them from being fully charged. Also intermediate, short drivings prevents the alternator from fully charging them up, which can also cause the memory effect. I live in Arizona and the summer heat also shortens the battery life dramatically. Quote Link to comment Share on other sites More sharing options...
lovlex Posted December 9, 2004 Share Posted December 9, 2004 if he has his lights to come on automatically when it gets dark, the manual will tell you, if you don't drive the car for a week or so, turn the system off because it can drain the battery. that could be the problem if the battery is 3 years old. Quote Link to comment Share on other sites More sharing options...
flanker271 Posted December 9, 2004 Share Posted December 9, 2004 Also make sure that you turn off the remote keyless entry switch located under the left side of the steering wheel. This could also drain the battery. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted December 9, 2004 Share Posted December 9, 2004 I had the same problem years ago i replaced my battery all the wires for grounds and to the starter and now it sits for weeks at a time with only occasional boosts found the cables were degrading and not giving the battery a full charge so it was very easy to die once it sat Quote Link to comment Share on other sites More sharing options...
jschunke Posted December 9, 2004 Author Share Posted December 9, 2004 Mucho gras for the constructive replies. Auto lights, remote keyless entry and ground are great suggestions. Maybe there are other automatic features that draw juice? Changing the battery every three years is a bit cautious, no? Quote Link to comment Share on other sites More sharing options...
silvermate Posted December 9, 2004 Share Posted December 9, 2004 well the keyless entry shouldn't draw any charge just sitting there. i beleive the only thing that should draw any charge is the OE alarm blinking light, and that wouldn't be enough to drain your battery, but i guess its possible if the car was sitting for a substantial amount of time, especially on an already weak battery. Changingthe battery every three years is a bit cautious, no? no, thats about right for an average battery, some say 5 years, but i've found thats really pushing it, 3 years is about right, just get her changed out and you'll be good to go. ;) also take SK's advice and clean/replace terminals, corroded battery cables and such, the corrosion eventually will spread like cancer, underneath the plastic cable housing, it might look clean but when u cut back the plastic, it will reveal a very corroded cable, that in itself, would cause a weak power supply its really simple to do, so i would reccomend doing that as well, as preventitive maintence, anyway. ( i did all that last year, its cheap and takes no time) good luck Quote Link to comment Share on other sites More sharing options...
lexus400 Posted December 10, 2004 Share Posted December 10, 2004 I just had a similar problem on an ES. Are you sure the battery is drained and doesn't just "sound" like it is ? My symptoms were "click, click" after sitting for several days. Sounded just like a dead battery but turned out to be a bad solenoid on the starter. Funny because this car has a 3 year old Diehard too... but it checks out fine. Bob Quote Link to comment Share on other sites More sharing options...
