scgold Posted September 17, 2004 Share Posted September 17, 2004 The rpm gauge has quite working in my 94sc400. Has anyone had similiar problem and know the solution? Could this just be a loose cable if so where are the connection points located. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
kmn5 Posted September 19, 2004 Share Posted September 19, 2004 check the pick up in the rear pumpkin Quote Link to comment Share on other sites More sharing options...
bean_8044 Posted September 19, 2004 Share Posted September 19, 2004 rear pumpkin? Quote Link to comment Share on other sites More sharing options...
Mr. Curious Posted September 19, 2004 Share Posted September 19, 2004 rear pumpkin? differential Quote Link to comment Share on other sites More sharing options...
SKperformance Posted September 20, 2004 Share Posted September 20, 2004 do you have a check engine light on? If not then it is your dash that is broken Quote Link to comment Share on other sites More sharing options...
bean_8044 Posted September 20, 2004 Share Posted September 20, 2004 Thats wierd..i thought the RPM came from a signal off the ignition coil Quote Link to comment Share on other sites More sharing options...
dcfish Posted September 20, 2004 Share Posted September 20, 2004 The problem sounds like it is in the instrument cluster itself , The three connectors behind the cluster do not usually come loose [ they are a b..ch to get out ] it is probably the guage itself . Is the needle still firing ? B) Quote Link to comment Share on other sites More sharing options...
teelias Posted November 3, 2004 Share Posted November 3, 2004 Smack the top of the instrument cluster (curved part). It worked for me Quote Link to comment Share on other sites More sharing options...
