1UZ-FE Posted July 20, 2004 Share Posted July 20, 2004 my 94's drivers door handle has been cracked since i bought the car 6 months ago. i have realized that it is starting to spread. someone recommended using JB weld. thoughts? ideas? any help is appreciated. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted July 20, 2004 Share Posted July 20, 2004 you can try the weld stuff since it is a funny metal alloy which is light and somwhat strong but it can;t be welded properly I think it is called white metal Quote Link to comment Share on other sites More sharing options...
chips229 Posted July 20, 2004 Share Posted July 20, 2004 :D :D I just fixed my drivers door handle on Sunday afternoon. The outside handle was fine but one of the brackets which holds the handle had cracked and broken on the inside....It looks a tricky job removing all the handle and frame as theres not alot of room inside the door....I mixed up some Araldite resin and that seems to have done the job. Good luck with your repairs Chips. Quote Link to comment Share on other sites More sharing options...
1UZ-FE Posted July 20, 2004 Author Share Posted July 20, 2004 I mixed up some Araldite resin and that seems to have done the job. could you please give more details on this product and where u got it and such. i would really like to fix my handle before it breaks. thx chips Quote Link to comment Share on other sites More sharing options...
chips229 Posted July 20, 2004 Share Posted July 20, 2004 I mixed up some Araldite resin and that seems to have done the job. could you please give more details on this product and where u got it and such. i would really like to fix my handle before it breaks. thx chips Hi again, The link below has a picture of the products they do...the stuff i used was in the red packet......dont use superglue thats to brittle and cracks...this araldite stuff goes off hard but has a sort of rubber feel to it and doesnt crack.....i fly radio controlled helicopters,well when i dont crash them :D this stuff helps keep they together Its the best stuff ive come across to stick anything to anything :D CLICK ME FOR INFO Chips. Let us know how you get on ;) Quote Link to comment Share on other sites More sharing options...
flanker271 Posted July 21, 2004 Share Posted July 21, 2004 i fly radio controlled helicopters I fly radio controlled ducted fan models Quote Link to comment Share on other sites More sharing options...
1UZ-FE Posted July 21, 2004 Author Share Posted July 21, 2004 i fly down the road in my LS! ;) thanks a lot for helping me out chips. Quote Link to comment Share on other sites More sharing options...
chips229 Posted July 21, 2004 Share Posted July 21, 2004 i fly down the road in my LS! ;) thanks a lot for helping me out chips. Let us know how you get on ;) "I fly radio controlled ducted fan models " :D Quote Link to comment Share on other sites More sharing options...
Autofanatic Posted January 27, 2005 Share Posted January 27, 2005 1UZ-FE did you fix your handle problem? mine has the exact same crack, albeit in a 1998. let me know how you fixed it. btw...im from raleigh too...small world Quote Link to comment Share on other sites More sharing options...
Shaggz Posted January 27, 2005 Share Posted January 27, 2005 I had the same problem in my 91 LS400. Mine got so bad that it actually came all apart eventually and I cut myself on it. :cries: Fortunately, it's quite a simple procedure to replace the door handle. I was able to find a replacement from a junkyard in good shape. I don't recall how much it cost, but it wasn't much at all. The lock mechanism swaps over to the replacement handle with the greatest of ease. Good luck, and watch those digits or you might get bit!! :o Quote Link to comment Share on other sites More sharing options...
ec437 Posted January 27, 2005 Share Posted January 27, 2005 Mine is beginning to develop similar symptoms. Do you have to take off the interior door panel to change the handle, or can it be done from the outside only? Outside would be sooo much easier than taking off the door panel. Quote Link to comment Share on other sites More sharing options...
Shaggz Posted January 27, 2005 Share Posted January 27, 2005 I believe the "outside only" approach is reserved for vandals.. :whistles: I'm sorry, but I'm pretty sure I had to do it from the inside. Getting the interior panel off is the hardest part of that job. But once you've done that once or twice it's not that difficult. Quote Link to comment Share on other sites More sharing options...
GRAND_LS 4 Posted January 31, 2005 Share Posted January 31, 2005 I believe the "outside only" approach is reserved for vandals..:whistles: I'm sorry, but I'm pretty sure I had to do it from the inside. Getting the interior panel off is the hardest part of that job. But once you've done that once or twice it's not that difficult. ← i have the same exact problem... Quote Link to comment Share on other sites More sharing options...
jadecuir Posted January 31, 2005 Share Posted January 31, 2005 You should stop-drill the end of the crack with a very small drill (.062 or smaller) to keep it from spreading. Then glue it up. Quote Link to comment Share on other sites More sharing options...
Shaggz Posted February 2, 2005 Share Posted February 2, 2005 I was just in the door tonite. I didn't take any pics this time, but I will in the daylight when I go back in to fix my current problem. My driver window stopped working, again. I'm afraid perhaps my replacement switch has now gone bad. At any rate, to get the interior panel off, you have to remove the 4 screws along the bottom of the panel, then the 1 screw near the latch area along the jam. This one actually holds a little plastic clip that hooks to the door frame on the backside of the interior panel. I believe there is 1 more screw in the handle area, but my plastic anchor is broken so I don't have to worry about that one <_< Once you have all the screws removed, you have to tilt the bottom of panel away from the car, then lift the entire thing straight up and out. It may take some gentle wriggling, but it will come out. When you pull it out, don't pull it too far because there are electronics that have to be disconnected, or layed aside for the lights and switches in the door. That's it though, and to get to the lock assembly, you just have to reach a 10mm socket or wrench in there and loosen the 1 bolt that anchors the lock to the handle and then 2 bolts that anchor the handle to the door. Good luck! :D Quote Link to comment Share on other sites More sharing options...
Autofanatic Posted March 23, 2005 Share Posted March 23, 2005 I just called my local lexus dealer and was quoted $132 for a handle with the factory matched paint. not bad, ive already got one on order.... Quote Link to comment Share on other sites More sharing options...
Dawnl Posted June 29, 2015 Share Posted June 29, 2015 my handle is broke were can i order one does anyone know please help i search e bay they do not have a drivers side fron door handle for 1998 ls400 is there a web site i can order it from thanks Quote Link to comment Share on other sites More sharing options...
LSPaul Posted June 30, 2015 Share Posted June 30, 2015 I was on the hunt for a replacement driver's door handle for my '94 last summer. For the earlier LS400s, the driver's door handles were still available from Lexus dealers (do a web search), but usually had to be ordered in. I found the best pricing online from a dealer in the Denver, CO area, but all that was left out there were handles in black, and I would have had to paint one to match. I ended up finding a good used driver's side front door handle on eBay in the correct color (a lucky find, as mine's the fairly rare "warm gray pearl" that was used on the 5th Anniversary cars. Paul Quote Link to comment Share on other sites More sharing options...
Dawnl Posted June 30, 2015 Share Posted June 30, 2015 e bay has none for my car the dealer here in miami wants 141.90 and junk yards dont have them for some reason NO ONE has any for 1998 I have searched the web for 2 days lol i just put some white girl looking duck tape on it looks fine for now :-) Quote Link to comment Share on other sites More sharing options...
LSPaul Posted June 30, 2015 Share Posted June 30, 2015 Yeah, that's what new outside door handles cost. The fact that one can actually *find* a new door handle to buy is pretty amazing, ya' know? Otherwise, '95-97 parts *might* fit (they're both UCF20 cars, like yours, but the part number is slightly different). Given that '98-00 used parts appear to be hard to find, it's worth a try. Good luck! Paul Quote Link to comment Share on other sites More sharing options...
Dawnl Posted July 1, 2015 Share Posted July 1, 2015 ya the dealer said it had to be ordered they didnt have it either I found another site were it has all handles for 106.00 the 95-97 parts wont fit i e mailed a guy on e bay he told me he didnt think they would fit :-( if i knew how to up load picture I would show you I fixed it with duct tape lol but not your normal grey duct tape I am just wondering why its so hard to find the part is my car special lol anyway have a great day :-) Quote Link to comment Share on other sites More sharing options...
billydpowell Posted July 7, 2015 Share Posted July 7, 2015 I got one from a salvage yard right color 15$ and put it on, worked perfect Quote Link to comment Share on other sites More sharing options...
