jkb005 Posted May 30, 2004 Share Posted May 30, 2004 Is a turbo kit made for the 1st gen GS 300? I just got one and i like it, but ofcourse i want it faster. Anyone got and leads for me? Quote Link to comment Share on other sites More sharing options...
jtanoyo1 Posted May 31, 2004 Share Posted May 31, 2004 You may contact: XS Engineering SP Engineering SRT Toyomoto These guys have built some serious hp on the 2jz-ge platform before. Quote Link to comment Share on other sites More sharing options...
tomanji Posted June 20, 2004 Share Posted June 20, 2004 xs engineering.. these the same guys as turboxs? they have a monster of a wrx also. Quote Link to comment Share on other sites More sharing options...
lexo Posted June 21, 2004 Share Posted June 21, 2004 :o Oh man.....you push it too far and you will need to focus on a ton of other (expensive areas ) How much boost do you have? What is the name of your kit? I have a (99) SRT kit. I found problems with the manifold design. In some cases you may be able to look into your manifold design, pipe sizes, down pipe size from turbo. Those are areas to look at for more power. What kind of injectors do you have? Most kits are set up for up to about 8lbs, though 6 is safe on a N/A motor. What about motor work? Pistons, rods? Pullys? Let me know what your shootin for and what you got. We can look over some areas.... :P Quote Link to comment Share on other sites More sharing options...
alexR Posted June 22, 2004 Share Posted June 22, 2004 I think you could boost a little more than 6 lbs on a 2jz and be safe....b16's can hold 6 lbs like nothin Quote Link to comment Share on other sites More sharing options...
TWINTURBO619 Posted June 23, 2004 Share Posted June 23, 2004 I think you could boost a little more than 6 lbs on a 2jz and be safe....b16's can hold 6 lbs like nothin honestly, i think you can pull 16 psi no problem. since the 2jz-ge has a lower compression ratio than the GTE, you'll be alright. now 18+ is pushing it, and 21+ is overkill. Think about it, this is toyota's pride and joy engine. bottom end are the same in both blocks with the exception of the compression ratio. these engines are able to take about 600hp without heavy modifications. i'm working on slapping a custom turbo kit and put out a goal of 450 hp daily driver. i have a friend in florida that's an expert in both lexus GSXXX's and toyota Aristo's. He owns both. Quote Link to comment Share on other sites More sharing options...
alexR Posted June 23, 2004 Share Posted June 23, 2004 i think going with a reasonable sized turbo and replacing a few injury-prone parts and pushin 4-500 HP reliably is a great way to go. I'd love to see what LS1's had to say after gettin smoked by a 2 ton luxury car. Well, from a roll anyways...I cant imagine a boosted aristo being anything special off the line... Quote Link to comment Share on other sites More sharing options...
