IndyRon Posted May 5, 2004 Share Posted May 5, 2004 I have 2 issues 1) air bag light is stuck on, dont know why, I tried unhooking the battery 2) also just got my brakes done and that dummy light is stuck on! Quote Link to comment Share on other sites More sharing options...
blake918 Posted May 5, 2004 Share Posted May 5, 2004 The airbag light won't go off with an unplugged battery. I had to pay a Toyota dealer to get mine turned off. Unless you drove the car w/o the airbag in, you have a problem in the SRS system, and correct me if I'm wrong, the SRS system will not work with the airbag light on. Get this checked ASAP! I don't know about turning the brake light off. Quote Link to comment Share on other sites More sharing options...
1UZ-FE Posted May 6, 2004 Share Posted May 6, 2004 DEFINATELY get that airbag light checked out if u care about the airbag going off should u be in an accident. If you really dont care about airbags, dont worry about getting that checked out. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted May 6, 2004 Share Posted May 6, 2004 they won;t work if the srs light is on. There is a complicated way of checking the system but it includes a multi step process of 1 second intervals and shorting out pins to 12vdc and ground.Not very safe for a novice to be doing with an ecu. the abs sensor on the hub may have become dislodged slightly from baning if you have a loose wheel hub. You need to check them for play. Quote Link to comment Share on other sites More sharing options...
obergc Posted May 6, 2004 Share Posted May 6, 2004 What year is your LS? I have the procedures for resetting the airbag light on a 93. Email me at obergc@cox.net if your have a 93. A common way the light gets triggered is to disconnect something like the instrument cluster without first disconnecting the battery. The procedure is a little tricky but has been done successfully by lots of folks. Quote Link to comment Share on other sites More sharing options...
