Hi,
All my door locks work as they should accept the pasanger rear door. It will only lock or unlock manually.
I understand Lexus does not use a door lock solenoid. But instead actually uses a gear motor to lock and unlock the door.
And that that motor is costly.
Anyone know of a good how to on fixing this? Anyone have any luck converting over to a cheep door lock solenoid?
Any help will be appreciated. Thank you.
