Bwest Posted December 4, 2016 Share Posted December 4, 2016 I have 94 ES300 with 127k miles on it. I drove this car from Los Angeles to Oregon with no problem at all. A day after I arrived the transmission started acting up. It would shut off on drive every time I pressed the gas. But it will drive in 2nd gear fine I've been driving in 2nd to start then I switch to drive and it runs fine. I don't know what the problem is any suggestions would help. I thought it was the throttle body at first cause it's done this before and my mechanic in ca cleaned the gunk out and it solved the problem till I arrived here. But I've been told it's the transmission. Please help. Quote Link to comment Share on other sites More sharing options...
Hoopes999 Posted December 4, 2016 Share Posted December 4, 2016 Make sure your ecm is not causing it, it's the computer located behind the glove box, that's what happened to mine Quote Link to comment Share on other sites More sharing options...
Bwest Posted December 7, 2016 Author Share Posted December 7, 2016 How do I check and fix if it is the problem? But an update I have not done nothing and sometimes the car will run perfect then sometimes it will repeat the cycle of only running in 2nd then to drive like I said above. Quote Link to comment Share on other sites More sharing options...
Hoopes999 Posted December 9, 2016 Share Posted December 9, 2016 The best way to do it is swap out for ecm with one from the junk yard that has the same part #, it's not difficult, just unplug the defective one and plug in the replacement and see if it fixes it...it should it's a classic symptom of a failing ecm especially in these order es300's . I have gone through three in 4 years, I had one that was starting me off in 2nd gear and another that was holding a fuel injector open and dumping raw gas into the exhuast Quote Link to comment Share on other sites More sharing options...
Hoopes999 Posted December 9, 2016 Share Posted December 9, 2016 Or find a used one on eBay just make sure the part # is the same Quote Link to comment Share on other sites More sharing options...
