i have read in some posts here that the stock system doesnt have bass mid and treble adjustments, and the nakim. does.. my 98 gs400 with navigation has the bass mid and treble adjustments in the audio area on the nav screen.. but there isnt a nakim. logo on the front of the unit.. sooo. is it a nakim. or stock????
To my knowledge the 98 and 99 did not come with a Nak system if you have the NAV. At least it was not offered when I bought my 99 GS4. The salesperson said it was NAK or NAV.
I don't have a definitive answer for you, but, my 99 is the same as yours.
I have nav and had read in Lexus sales docs that you cannot get the Nakamichi and Nav together.
I have the bass/mid/treble adjustment like you do, but am not sure if this radio is a slight upgrade over the stock radio. (I have 6CD too, as I presume you do, but again, I'm not sure if they all came with it)
Someone with a GS with a standard radio should answer this but isn't the knob on the right side of the radio a multifunction knob that adjusts treble, mid-range and bass? I think it works like a similar multifunction knob on our Camry but I can ask our secretary who has a GS300 tomorrow. As least in the LS, the Nav and stock radios had similar output specs and the same amplifier. The Nak system in the 2000 LS actually had 5W less output at each tweeter and midrange speaker but about twice the output from the subwoofer in the rear deck.
The 98 Pioneer system (non Nav) has Bass/Mid/Treb controls. I don't think you have Nak.
May not really help with your quesiton, but look in your trunk on the right side and see if there is an amp there. I think the NAK upgrade included the AMP but the standard radio doesn't have it.
that would be interesting because I have that amp (or some 12" piece of electronic gizmo) there in the trunk.
perhaps there was a mid-grade stereo system?
Hey guys. I have a 99 GS4 with the Nakamichi. It has all three knobs for bass/mid/treble. The big knob on the left is just volume, not multifunction. I don't have Nav as I wanted the Nakamichi. Hope this helps.
KJ
yes, i have the nav.....
You do to, right?? Do you have that amp in the right side of the trunk?
Edit:
The more I think about it, the more I have to go back to the original post Blue....
"i have read in some posts here that the stock system doesnt have bass mid and treble adjustments, and the nakim. does..."
I don't think that's a correct statement in that other thread.
KJ
ditto on my 1998 gs400
