My 1994 ES 300's speed and tach and red pointers are gradually "burning out" and are not properly illuminated any more. Lighting of segments of the pointer flicker on and off. It appears to be temperature sensitive. Sometimes very little of the pointer is illuminated, other times much of the pointer is illuminated. The problem started about 2 years ago and is getting worse.
Can this be repaired at reasonable cost?
nice find, i love they give you alot of info...maybe you should try to do it yourself first =P and save the $99 + SH
I just gotta get my speed sensor, heated seat switch, and hood struts issue fixed first. The timing belt, water pump, belts, cam seals, and other ignition compnents have really drained my money B)
Sohaib
