Trans Leak
tim john
Hello, quick question, will flushing a trans. cause a trans to leak where the trans and motor mate? I have a 04 ES, 70000 miles, had fluid changed and flushed at about 60000 miles, leak didn't happen till about 9-10 months later. Had car since new. They used a B-G system to flush. Said it was low preasure, took a while to complete, watched them hook up run the system. No shifting problems. Leak fixed by dealer on warrenty. Thanks.
Tim
Definately trans fluid...
I would personally think its just a breakdown of the transmission gaskets more than the flush you had done.
Had it happened right after the flush I'd feel differently...
Every 15,000 drain and refill byself. Next 15,000 take it to mechanic for drop pan change filter and refill trans.
I maintained my 97 ES300 this way and until it was totaled at 362K, trans was running like New.
362K miles? Wow! Good job!!
