jgilbert Posted February 9, 2010 Share Posted February 9, 2010 Does anyone know how to turn off the green Eco light on the dashboard of a 2010 ES 350? The instruction manual gives no advice on this topic. Quote Link to comment Share on other sites More sharing options...
joeb427 Posted February 10, 2010 Share Posted February 10, 2010 Does anyone know how to turn off the green Eco light on the dashboard of a 2010 ES 350? The instruction manual gives no advice on this topic. I hated that green econo light too. :D I forgot exactly how I did it months ago but it's done on the steering wheel display button somehow when you get to the econo display in the window. Hopefully someone will reply. Quote Link to comment Share on other sites More sharing options...
timzter Posted February 10, 2010 Share Posted February 10, 2010 >>> I hated that green econo light too. biggrin.gif I forgot exactly how I did it months ago but it's done on the steering wheel display button somehow when you get to the econo display in the window. Hopefully someone will reply. <<< I believe the ECO Light can only be turned off by the dealer--Page 514 of 2010 ES 350 Owner's Manual. Quote Link to comment Share on other sites More sharing options...
joeb427 Posted February 10, 2010 Share Posted February 10, 2010 >>>I hated that green econo light too. biggrin.gif I forgot exactly how I did it months ago but it's done on the steering wheel display button somehow when you get to the econo display in the window. Hopefully someone will reply. <<< I believe the ECO Light can only be turned off by the dealer--Page 514 of 2010 ES 350 Owner's Manual. Not correct.I did it. It's done somehow with the display button on the wheel. If I remember correctly,you must hold in the display button when you get to the eco display on the screen but it definitely can be shut off without dealer imput somehow. Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted February 10, 2010 Share Posted February 10, 2010 Does the light always stay on or does it come on only when your driving with a gentle foot? Quote Link to comment Share on other sites More sharing options...
joeb427 Posted February 10, 2010 Share Posted February 10, 2010 Does the light always stay on or does it come on only when your driving with a gentle foot? On and off.I believe it comes on when you're driving in a gas saving way. I found the green light to be quite distracting and annoying. Quote Link to comment Share on other sites More sharing options...
timzter Posted February 11, 2010 Share Posted February 11, 2010 Well, I'd like to know how you do it. Again, you're saying you could set the ECO light permanently off no matter whether you are driving economically or not. Quote Link to comment Share on other sites More sharing options...
joeb427 Posted February 11, 2010 Share Posted February 11, 2010 Well, I'd like to know how you do it. Again, you're saying you could set the ECO light permanently off no matter whether you are driving economically or not. Yes. By using the steering wheel display button,you can see a Eco off display on dash when it's turned off. Directions are in the manual somewhere.Try holding the display button down when you get to the eco window display. It's done somehow with that button.I don't remember how and don't want to screw with it. :) Quote Link to comment Share on other sites More sharing options...
hmrnmky Posted March 12, 2010 Share Posted March 12, 2010 You use the DISP button on the steering wheel to toggle to the ECO light setting. Hold in the DISP button for several seconds and the indicator will change to either off or disabled, I forget. You can also turn it back on the same way. Quote Link to comment Share on other sites More sharing options...
K.C. Dia Posted March 13, 2010 Share Posted March 13, 2010 You use the DISP button on the steering wheel to toggle to the ECO light setting. Hold in the DISP button for several seconds and the indicator will change to either off or disabled, I forget. You can also turn it back on the same way. You keep punching the DISP switch on the right side of the steering wheel. Each time you punch it the display screen where the steering wheel goes into the dashboard toggles through a different display. There are about eight of them. When you get to a screen that says "ECO INDICATOR ON", hold the DISP button in for one second or longer and the screen will turn to ECO INDICATOR OFF. You can then keep pushing the DISP button until you get the screen you want. You toggle the ECO indicator back on the same way. Quote Link to comment Share on other sites More sharing options...
K.C. Dia Posted March 13, 2010 Share Posted March 13, 2010 You use the DISP button on the steering wheel to toggle to the ECO light setting. Hold in the DISP button for several seconds and the indicator will change to either off or disabled, I forget. You can also turn it back on the same way. You keep punching the DISP switch on the right side of the steering wheel. Each time you punch it the display screen where the steering wheel goes into the dashboard toggles through a different display. There are about eight of them. When you get to a screen that says "ECO INDICATOR ON", hold the DISP button in for one second or longer and the screen will turn to ECO INDICATOR OFF. You can then keep pushing the DISP button until you get the screen you want. You toggle the ECO indicator back on the same way. I forgot to add that this can only be done while the vehicle is stopped. Apparently Nanny Lexus thinks that we may crash and burn while attempting to perform this extremely difficult maneuver. Lexus believes that we Lexus drivers can't chew gum and !Removed! at the same time. Quote Link to comment Share on other sites More sharing options...
