akkeith Posted June 19, 2009 Share Posted June 19, 2009 Can anyone tell me if 255's can be run on the RX400H? Will the rub when turned all the way in one direction? What about affect on the warranty? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
RX400h Posted June 19, 2009 Share Posted June 19, 2009 There are a couple of forum members who have or have had 255s on their RX400hs. Most likely, they will chime in as there are no shortages of opions about tires in this forum. I have the OEM-size Bridgestone Alenzas and I am very happy with them - great wear and handling, wet or dry. Quote Link to comment Share on other sites More sharing options...
RXREY Posted June 19, 2009 Share Posted June 19, 2009 I have Toyo Proxes S/T s ( two and a half years,25K miles) and they have been great with absolutely no rubbing or any problems. They are 255/55/18 and I think the 1/2" bigger size looks better. I make the adjustment when I calculate my MPGS and add 3%. This is the largest anyone should go though and when these wear out I will get Toyo Versado L/X or perhaps change to Bridgestone Alenzas or even another brand but I will keep the 255 size. Rey Quote Link to comment Share on other sites More sharing options...
pinggolf Posted September 9, 2009 Share Posted September 9, 2009 I have Toyo Proxes S/T s ( two and a half years,25K miles) and they have been great with absolutely no rubbing or any problems. They are 255/55/18 and I think the 1/2" bigger size looks better. I make the adjustment when I calculate my MPGS and add 3%. This is the largest anyone should go though and when these wear out I will get Toyo Versado L/X or perhaps change to Bridgestone Alenzas or even another brand but I will keep the 255 size. Rey Than I will assume ordering a set of Yokohama Parada Spec-X 245/60/18's will fit fine??? Or am I assuming wrong? Thanks Quote Link to comment Share on other sites More sharing options...
skyfish400h Posted September 11, 2009 Share Posted September 11, 2009 I have Toyo Proxes S/T s ( two and a half years,25K miles) and they have been great with absolutely no rubbing or any problems. They are 255/55/18 and I think the 1/2" bigger size looks better. I make the adjustment when I calculate my MPGS and add 3%. This is the largest anyone should go though and when these wear out I will get Toyo Versado L/X or perhaps change to Bridgestone Alenzas or even another brand but I will keep the 255 size. Rey Than I will assume ordering a set of Yokohama Parada Spec-X 245/60/18's will fit fine??? Or am I assuming wrong? Thanks There is a tire size calculator on this forum so you can visualize the changes in tire size. Here is a chart of tires and sizes that I was considering at the time I bought the Goodyear ResponseEdge. size dia rot name 245/50 VR18 27.8 746 advan 255/50/R18 27.9 744 toyo 50 235/55 VR18 28.0 746 eagle rs 235/55 VR18 28.2 739 bridgestone 235/55 VR18 28.3 736 s8 235/55 VR18 28.4 731 mxm4 245/55 ZR18 28.5 724 kdws 255/55 VR18 29.0 720 eagle edge 255/55R18 29.0 718 toyo 255/55VR18 29.3 706 zero Quote Link to comment Share on other sites More sharing options...
Agosin Posted September 13, 2009 Share Posted September 13, 2009 I have Toyo Proxes S/T s ( two and a half years,25K miles) and they have been great with absolutely no rubbing or any problems. They are 255/55/18 and I think the 1/2" bigger size looks better. I make the adjustment when I calculate my MPGS and add 3%. This is the largest anyone should go though and when these wear out I will get Toyo Versado L/X or perhaps change to Bridgestone Alenzas or even another brand but I will keep the 255 size. Rey Than I will assume ordering a set of Yokohama Parada Spec-X 245/60/18's will fit fine??? Or am I assuming wrong? Thanks Hi, I used 255's for months then switched to 275's which I have been wearing for almost two months now. Just perfect. Quote Link to comment Share on other sites More sharing options...
Gryphon Posted September 16, 2009 Share Posted September 16, 2009 I guessing that the price of tires will soon be going up if the 60% tariff on Chinese tires really happens. That would also include American made tires of course. Tom Quote Link to comment Share on other sites More sharing options...
