Hi guys, bothering you again,
I have a leak and want to use some stop leak treatment until I have enough money to find it and fix it but the 95 LS 400 does not have a radiator fill neck, it only has an expansion reservoir, can i put the stop leak in here and can you guys recommend something?
Thanks in advance.
It will not work by using the res.
Do not use it as it will partially block passages.
Keep topping off the fluid or Fix it proper or don't drive it.
+1 DO NOT USE
Just continue to top off until you can fix it.
Have a shop pressure test the system, find the leak, find out their cost, then make your plans accordingly.. bp
Rule of thumb or when it comes to cars, more like "rule of knuckle":
If you can't fix it right, then don't make it worse!
